Thread: Found my ABS/Trac off light issue...
Results 1 to 2 of 2
  1. #1 Found my ABS/Trac off light issue...
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    3 weeks ago heading up to GF's ran over a piece of wood going about 20mph, going up a mountain, following another car. it was a 12"x12" with a 2"x12" piece connected to it at 90 degree (about 3/8" thick). It was too late to dodge the thing following the car in front of me.
    Anyway, since then my ABS/Trac off lights has been coming on sporadically, was finally able to check my wheel bearings/hubs out today.
    Turns out the wire on the passenger side front ABS sensor was rubbing up against the half shaft (how long no clue, or if the hitting the wood did it) and rubbed thru the casing and I seen 2 bare strands, taped them up and no more ABS/Trac off lights for the time being. Have to replace the engine/tranny mounts soon, so will check at that time to see how it's holding up and decide what to do from there.
    Figure someone else may have the same issue.
  2. #2 Re: Found my ABS/Trac off light issue...
    Windsor (ON) Canada
    I have abs/traction light issues.. but i didnt hit no wood haha... just a bad hub (replacing next week)
    You luck Bas*ard...
  1. Tac quits and goes to zero/trac off light comes on
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2012, 05:37 PM
  2. abs and trac light on
    By 99silvergtp in forum Off Topic Discussion
    Last Post: 01-07-2010, 07:32 AM
  3. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  4. my low trac is lit and so is the abs light
    By beast55 in forum General Tech Discussion
    Last Post: 06-27-2009, 01:23 PM
  5. Trac Off Issue
    By catcamvegas in forum General Tech Discussion
    Last Post: 07-25-2008, 10:01 AM
