Thread: Oversized brakes or not?
Results 1 to 15 of 15
  1. #1 Oversized brakes or not?
    GT Level Member AdamBall's Avatar
    Wausau, WI
    Just wondering if it would be worth the time and money to go oversize or not.
    I came across this setup. Any input would help thanks!
    Baer Eradispeed Big Brake Upgrade - 97-03 Grand Prix - Suspension & Brakes
  2. #2 Re: Oversized brakes or not?
  3. #3 Re: Oversized brakes or not?
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    I did the 12" front conversion with the WS6 rotors and new caliper brackets, cheap and works great. I know this swap will not work with all the factory wheels though.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  4. #4 Re: Oversized brakes or not?
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    you can use your stock calipers, just go buy some 12" rotors for a 04 Impala, and a pair of caliper brackets for the same. Save your big $$$$ for go fast parts.
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  5. #5 Re: Oversized brakes or not?
    Wausau, WI
    you guys have any links for a good place to get these parts from?
  6. #6 Re: Oversized brakes or not?
    Nov 2009
    wentzville
    I think I got mine from ZZ Performance.
    1969 Pontiac GTO
  7. #7 Re: Oversized brakes or not?
    all i had was the GM 12" upgrade on my car (not f-body) and it stopped great with a nice set of pads.
  8. #8 Re: Oversized brakes or not?
    Do this and get good pads... pads make a big difference.
    Change your brake fluid.
    Get an impala brake booster.
    That should be about it.
  9. #9 Re: Oversized brakes or not?
    Jan 2009
    Tallahassee, FL
    What does the Impala booster do?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #10 Re: Oversized brakes or not?
    Jul 2008
    sumter,south carolina
    minichopper6hp sells powdercoated Fbody calipers, brackets for a very reasonable price.
    02 GTP with mods 05 GP for DD
  11. #11 Re: Oversized brakes or not?
    Quote Originally Posted by Sandman View Post
    Much better brake feel.
    Search for "impala brake booster"
    should find these two threads:
    http://www.grandprixforums.net/f59/b...-one-8297.html
    http://www.grandprixforums.net/f59/s...pungy-161.html
  12. #12 Re: Oversized brakes or not?
    SE Level Member Crave Energy's Avatar
    Oct 2008
    San Jose
    Quote Originally Posted by AdamBall View Post
    If the price isn't an issue the Baer brake set up is sweet, especially the light weight two piece rotors.
  13. #13 Re: Oversized brakes or not?
    Quote Originally Posted by Crave Energy View Post
    Many other faults in our brake systems already...
    Lack quality pads, stainless brake lines, crappy brake booster, no rotor cooling, too much nose dive, wet brake fluid etc.
  14. #14 Re: Oversized brakes or not?
    GTX Level Member real diehl's Avatar
    Salina, KS
    I drive slow, I don't need to worry about stopping.
    signature removed for inappropriate content.
    -bio
  15. #15 Re: Oversized brakes or not?
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    Honestly big brake kits are a WASTE of money. A huge waste unless you plan on doing track racing your GP which I'm pretty sure these cars are not known for. Anyways it's GM just some GM brake parts, stainless lines because all these cars have spongys ass brakes, good pads w/o brake dust ceramics are good I don't know what OE are, and you should be good to go dude, and you will save like at least $750.
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  1. Need new brakes
    By 04gpking85 in forum Brakes/Suspension/Chassis
    Last Post: 08-07-2010, 07:11 PM
  2. What brakes should i go with?
    By Whitehispanic in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2009, 06:36 PM
  3. Brakes
    By Wadeb79 in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2009, 10:11 PM
  4. ZZP oversized radiator, link to the cheaper ones on Ebay?
    By Tengis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2008, 06:47 AM
