Thread: so i have questions about sway bars.
Results 1 to 20 of 23
  1. #1 so i have questions about sway bars.
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    didnt see it anywhere here...so. are they worth replacing? i mean they have kits with sway bars and bushings claiming theyre bigger and stronger but ive done measurements and my bars are the same size as the aftermarket. so whats the difference? are they better material or bent differently or is it just the bushings that make a difference? any help? this isnt my field but id like to have this knowledge... thanks guys.
  2. #2 Re: so i have questions about sway bars.
    bigger sway bars with poly bushings will help a bunch. the only thing i would do before sway bars are the trailing arms.
  3. #3 Re: so i have questions about sway bars.
    Wooster, Ohio
    GM performance parts bars from Summit Racing, best price's period. +1 about the trailing arms as i just picked up a unused set of GMPP arms for $20!
  4. #4 Re: so i have questions about sway bars.
    GTX Level Member Deimos's Avatar
    iowa
    do the aftremarket ones break as easy as the stock ones (sway bars) or are they made out of the same material?
  5. #5 Re: so i have questions about sway bars.
    Wooster, Ohio
    No, they don't have the crushed and welded tube ends like the stock ones, which is the weak breaking point.
  6. #6 Re: so i have questions about sway bars.
    iowa
    heck yeah it is I don't know how many I had to reweld or epoxy, or replace but it's like that on ventures, centurys, sillhouettes all sorts of gm cars.
  7. #7 Re: so i have questions about sway bars.
    seriously, trailing arms first. next if you only want to do one sway bar: do the rear (but id recommend both). then lower the car.
  8. #8 Re: so i have questions about sway bars.
    GT Level Member pski920's Avatar
    Oct 2008
    Endicott NY
    what kind of trailing arms are you talking about, bio? the ones from zzp? or somewhere else? i have to do some suspension work (i.e. struts, lowering springs, strut mounts, maybe sway bars, and now trailing arms lol). thanks.
  9. #9 Re: so i have questions about sway bars.
    just the tubular GMPP ones. if you want something expensive then have fun trying to find a speedbuilt or BMR set.
  10. #10 Re: so i have questions about sway bars.
    Oct 2008
    Endicott NY
    ahh, i didn't know GMPP made anything like that, are they still avail. from gm?
  11. #11 Re: so i have questions about sway bars.
  12. #12 Re: so i have questions about sway bars.
    Oct 2008
    Endicott NY
    ^^^thanks. i'll look into it, since i'll be diving into some suspension work soon.
  13. #13 Re: so i have questions about sway bars.
    Dec 2008
    Lawndale, CA
    FYI the GMPP trailing arms have been discontinued. UMI makes a nice set of trailing arms. A member on another forum picked up a set at a good price on ebay. I have also read that the Grand Prix GXP trailing arms are good replacement for the GMPP one's.
  14. #14 Re: so i have questions about sway bars.
    Texas
    i hate to intrude on the topic. but do grand prix's of the same body style have the same sway bars? for instance does a 98 grand prix 3.1 SE have the same sway bar as any other simaler body style grand prix?
  15. #15 Re: so i have questions about sway bars.
    New York
    Quote Originally Posted by kswissbob View Post
    Yes, I believe, that all the 01-03 GP's have the same sway bars, front and rear, the springs rates are diifferent. Definitely, the 2001-2003's. I think that the 97-00's may have different size bars based on gmpartsdirect.com since they listed the early years differently, although the price is exactly the same, thus my being unsure about the earlier years!
  16. #16 Re: so i have questions about sway bars.
    Oct 2008
    Endicott NY
    Quote Originally Posted by The Guz View Post
    thanks, i'm sure it'll be easier to find the UMI arms, than a set of orig GXP's? Hopefully when i go to do my work, i'll be able to find what i'm looking for. Where can i buy a set of UMI's if i cant find a GMPP part?
  17. #17 Re: so i have questions about sway bars.
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by pski920 View Post
    You can get them straight from them.
    1997 - 2005 GM W-Body Tubular Rear Trailing Arms [3715] - $109.99 : UMI Performance, Inc.
    You can find them on ebay once in awhile at a slight cheaper price.
  18. #18 Re: so i have questions about sway bars.
  19. #19 Re: so i have questions about sway bars.
    CRAP! GMPP ones were $42 I've got them...along with the GMPP FSTB, FSB and RSB.
  20. #20 Re: so i have questions about sway bars.
    Oct 2008
    Endicott NY
    is the quality the same between all these brands? or is it just a price/name brand difference?
  1. Sway Bars
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 11-12-2009, 04:23 PM
  2. GMPP Sway Bars installed
    By dhall9 in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 02:04 PM
  3. Sway bars
    By speedemongtp in forum Brakes/Suspension/Chassis
    Last Post: 06-22-2009, 11:41 AM
  4. Sway Bars
    By RicerKiller in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2009, 12:14 AM
  5. Help with finding sway bars for 05
    By John_Shughart in forum Brakes/Suspension/Chassis
    Last Post: 03-25-2008, 11:42 AM
