Thread: What brake setup should I buy?
Results 1 to 20 of 22
  1. #1 What brake setup should I buy?
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Hey guys. I have a 2001 Grand Prix GT, but I'm going to be doing a L67 top swap on it fairly soon, along with several other power modifications. Before I do all this, I'm taking preventitive measures to ensure my car is equipped to handle the extra power. I'm just wondering what brake setup you guys would recommend (front and back). Thanks guys.
  2. #2 Re: What brake setup should I buy?
    cheapest, most worthwhile setup is just a normal GM 12" upgrade. thats all i did and the car stopped great. the next best option is f-body brakes.
    for the rears, just make sure youve got fresh pads and rotors on them. they really dont help with braking all that much and the only "upgrade" available is to downgrade to grand am brakes that are lighter, but stop worse.
  3. #3 Re: What brake setup should I buy?
    Jan 2009
    Tallahassee, FL
    If you got the money you can find a GXP brake setup, but really a 12" front with the F-body calipers is more than enough. The rears are fine. Be sure to get good pads and new fluid to.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  4. #4 Re: What brake setup should I buy?
    Serena, IL
    Will the Fbody brakes fit behind the stock 16 inch snowflake rims?
  5. #5 Re: What brake setup should I buy?
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Nope, you'll need atleast a 17" rim to clear the caliper
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  6. #6 Re: What brake setup should I buy?
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Quote Originally Posted by ninnyGTP View Post
    Not true, they will clear stock 16" wheels except for these..
  7. #7 Re: What brake setup should I buy?
    Quote Originally Posted by BlownBigBlock View Post
    those wheels OR the snow flakes.
  8. #8 Re: What brake setup should I buy?
    Nov 2008
  9. #9 Re: What brake setup should I buy?
    What about stock calipers with 12" rotors on snowflakes?
  10. #10 Re: What brake setup should I buy?
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    Well u can't fit the stock calipers over 12" rotors. That's why u need the caliper and caliper bracket off of an f-body
    2003 GTP- 180 tstat,tb spacer,flipped dogbones,dhp pcm,3"catless dp,plog,thrasher fwi,3.4 pulley,msd 8.5mm wires,autolite 104s----------best run so far:14.1 @97mph
  11. #11 Re: What brake setup should I buy?
    Quote Originally Posted by superv6 View Post
    the GM 12" caliper bracket with the stock rotor and 11.9" rotors will work fine with any wheel setup.
  12. #12 Re: What brake setup should I buy?
    Where's the best place to get the GM 12" upgraded brake system?
  13. #13 Re: What brake setup should I buy?
  14. #14 Re: What brake setup should I buy?
    Joliet, IL
    f-body ftw....if your on a budget do the 12" upgrade....especially if you got the wrong wheels....it works well to from what ive heard....i however have always been a fan of the f-bodys they make me feel alot safer when braking....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  15. #15 Re: What brake setup should I buy?
    hope that helps?
  16. #16 Re: What brake setup should I buy?
    Serena, IL
    Quote Originally Posted by boosting98 View Post
    hope that helps?
    ill try it with the snow flakes, if not ill switch to these, i have a set of dr's on 2 and th other two are just sitting on the parts car. I'd really like to keep the Snowflakes as they are in better shape and are polished....don't really want to polish those up.
  17. #17 Re: What brake setup should I buy?
    Joliet, IL
    Quote Originally Posted by xringshooter7 View Post
    take the snow flakes off....5 spokes ftw
    00 Silvermist GTP
  18. #18 Re: What brake setup should I buy?
    Serena, IL
    Quote Originally Posted by BoostJunki3 View Post
    the 5 spokes need some work, the snowflakes are in nice shape
  19. #19 Re: What brake setup should I buy?
    Topeka, KS
    Umm... For what it's worth I have STOCK Calipers with 11.9 - 12 Inch Rotors on 16" Rims. The only ones that you can not do this upgrade with is the Cross laced Wheel pictured above.
    To do this all you need is to get ahold of a junk yard and get Oldsmobile Intrigue Caliper Brackets and a Good Set of 11.9 AKA 12" rotors from any parts store. It does make quite a difference.
    I got the brackets and 2 rotors from Ed Morad for $55.00 shipped. But you're better off using new rotors and pads.
  20. #20 Re: What brake setup should I buy?
    Donating Users ARFF22's Avatar
    NEW YORK
    So that 12" upgrade set-up will work with these wheels?
  1. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
  2. 3.4 setup questions.
    By Perry125 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2009, 04:01 PM
  3. New setup
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2009, 11:00 PM
  4. this setup
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2008, 08:47 PM
