Thread: '04 rear caliper leak
Results 1 to 2 of 2
  1. #1 '04 rear caliper leak
    NH
    Apparently the right rear caliper has started to leak. I'm wondering how big a deal it is to replace, and I hear the left one should be replaced at the same time for system balance.
    Thanks!
  2. #2 Re: '04 rear caliper leak
    pop the wheels off, pop the calipers off, detach brake line, hold brake line as high as possible till you attach it to the new caliper, bleed brakes, put the wheels on and go.
    Ever changed your pads before? One thing to note is apparently the 04+ require a tool to twist the piston to get it to retract. Caliper should already be compressed enough to get it on though.
  1. Leak right rear wheel.
    By itsjay in forum Brakes/Suspension/Chassis
    Last Post: 10-28-2009, 11:11 PM
  2. '04 rear caliper piston
    By 04GT2 in forum Brakes/Suspension/Chassis
    Last Post: 07-22-2009, 12:26 PM
  3. Slightly Hanging Rear Right Caliper
    By JoshMcMadMac in forum Brakes/Suspension/Chassis
    Last Post: 01-17-2009, 05:52 PM
  4. 2002 Grand Prix - Right Rear Brake Leak
    By johngandersonjr in forum Brakes/Suspension/Chassis
    Last Post: 12-18-2008, 09:43 PM
