Sounds like you have a bad wheel bearing, a bad wheel speed sensor or an EBCM failure. But if you’re the luckiest guy on the planet, check your brake fluid level it might be low.
I guarantee (or your money back ) it is one of the four, the only expensive fix is the EBCM. Good Luck and give us an update if you could.
