Thread: GMPP Sway bar frame bushings???
Results 1 to 9 of 9
  1. #1 GMPP Sway bar frame bushings???
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    PLEASE HELP!
    I have someone trying to install the GMPP front swaybar on my GTP... first hurdle is the 3" DP... remembered that i read that the bar has to be flipped-- second, and more importantly -- the installer says that the midpoint bushings are an inch taller than the hold down bracket pieces... is this normal??? what do i do? (rubber is taller than the metal strap bracket pieces....
    thanks
  2. #2 Re: GMPP Sway bar frame bushings???
    Banned - Busted For Scamming
    Feb 2009
    Make it fit, its rubber. You are using the gmpp bushings, correct?
  3. #3 Re: GMPP Sway bar frame bushings???
    SW Chicago Suburbs
    yes, the ones that came with the bar
    is it really a case of make it fit, or are there different clamp/braket pieces? the taller part seems to be on the bottom, making more clearance between the cradle and the bar...
  4. #4 Re: GMPP Sway bar frame bushings???
    Feb 2009
    They will clamp down, use a little lubrication and they will go around it, smash down just fine. Its a tight fit, but its good that way.
  5. #5 Re: GMPP Sway bar frame bushings???
    SW Chicago Suburbs
    he's gonna give it a go-- especially since now he says it's like a half inch gap.. that'll squish
  6. #6 Re: GMPP Sway bar frame bushings???
    SW Chicago Suburbs
    the only other explaination i can think of is perhaps a production change to a taller bracket/bushing somewhere after the 97 MY? ... i have a late 97 (no whip antenna)
  7. #7 Re: GMPP Sway bar frame bushings???
    Feb 2009
    Should have nothing to do with it, its just tight fit, the way its supposed to be.
  8. #8 Re: GMPP Sway bar frame bushings???
    New vs old and crushed. That's what I figure it usually is.
  9. #9 Re: GMPP Sway bar frame bushings???
    SW Chicago Suburbs
    yeah that's what i figured- it's been awhile since i changed one of these, and even then i reused the bushings. I looked the car up on rockauto and did find Moog bushing p/n's for the 34MM bar, (poly i think, but not sure) so if these just won't go, I'll have them nab some of those and see how they compare, i bet they are the same though
  1. P/Ns Sway Bar Bushings for 32mm/22mm Bars
    By TommyGloves in forum Brakes/Suspension/Chassis
    Last Post: 07-14-2009, 05:31 PM
  2. GMPP Sway Bars installed
    By dhall9 in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 02:04 PM
  3. GMPP Sway Bar/Suspension Kit
    By BlownBigBlock in forum Brakes/Suspension/Chassis
    Last Post: 06-16-2009, 11:24 AM
  4. Sway bar bushings
    By TDCRacing in forum Shops and Community Heroes
    Last Post: 09-13-2008, 03:47 PM
  5. GMPP Sway Bar
    By Berger in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2008, 09:07 AM
