Thread: Back brakes!
Results 1 to 6 of 6
  1. #1 Back brakes!
    SE Level Member J4pro2001's Avatar
    Crown Point, IN
    I just put new brakes on my 2000 grand prix. Now the brake power feels way less like the backs dont work any idea?
  2. #2 Re: Back brakes!
    HUDSON
    What did your brake job consist of? Rotors&pads, or just pads, or did you have the rotors turned?
    Try getting them hot and see how they work, some pads don't work well untillthey are hot, some need more heat than others. Just go to a road with low traffic and make some safe hard stops. This will tell you how hot they have to get beofre they feel good, what type of pads did you put on? I have also found that when shops turn the rotors they dont have the correct finish to them and it takes a while for the pads to bite. For this reason I always just buy brand new rotors.
    Dean
  3. #3 Re: Back brakes!
    Jul 2008
    Poteau Oklahoma
    did you clean your rotors befor you took off? oils getting on your pads can cause this.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  4. #4 Re: Back brakes!
    Crown Point, IN
    I put brand new pads and rotors! The peddle feels stiff untill half way then it starts to get musshy! the rears don t have as much power!
  5. #5 Re: Back brakes!
    when u say mushy i cant help but think i would at least start by going through some fluid and bleeding the brakes again, and possibly again. top dollar equipment means nothing if they have air in the lines or possibly think if getting stainless brake lines i know that will help the pedal feel for sure!
  6. #6 Re: Back brakes!
    Crown Point, IN
    Quote Originally Posted by 02GrandPrixIraqVet View Post
    yeah i do about 50 brake jobs a week lol and this never happens. I found out that it was my master cylinder!!! I put a booster and 2 different sets of pads and rotors! They are all kinda mushy the gxps are not like that at all!
  1. No brakes...HELP!!
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-17-2009, 01:40 PM
  2. need help getting my back window back on track
    By GrandPrixGT00 in forum Visual/Body Modifications
    Last Post: 06-15-2009, 04:06 PM
  3. What brakes should i go with?
    By Whitehispanic in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2009, 06:36 PM
  4. Brakes
    By Wadeb79 in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2009, 10:11 PM
  5. Hot Brakes
    By jgold8604 in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2008, 04:16 PM
