Thread: Stupid brakes are spungy
Results 1 to 20 of 34
  1. #1
    Oklahoma
    Fbody brakes would make it worse because they have larger pistons I believe and they brake booster would not handle it well. They will work and stop the car, but if you think OEM ones are spongy, the Fbody brakes will be worse. I can see where one would consider our brakes spongy, but they are no worse than any other cars Ive been in.
    Wichita, KS
    They have two pistons, but smaller than the one single stock one, but require more fluid to move them both = spongy brakes. If you do the F-Body brakes, you MUST run stainless brake lines to firm them back up.
    The GF's GTP has some of the firmest brakes I have ever set up. I powder coated and rebuilt her calipers at least 4 years ago now, and still going strong. I believe the shape and condition of the master cylinder, and brake booster have a lot to do with brakes and how they preform.
    Mine are soft compared to hers, but still firmer than other cars I have driven.
    ~F~
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Just running the stainless steel brake lines on my stock setup was a huge improvement.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
