Thread: Stuck Caliper bolts
Results 1 to 6 of 6
  1. #1 Re: Stuck Caliper bolts
    SE Level Member ceelo's Avatar
    atlanta
    yea same problem on drvr side top brake caliper bracket bolt was/is stuck
    i had changed brkes about a year ago with cmax brakes from az and used the black packet that came with the brakes thinking/told it was brake lubricant but i don't know if this was the cause at any rate had to use a breaker bar to break bolt and even after breaking bolt it was hard as hell each rotation
    finally once it was totally unscrewed had to use grip pliers turning it back and forth to ease bolt out of bracket
    this time used brake cleaner and steal wire brush to clean bolt which made it better but still brown colored, i will buy new bolt nxt time do this job, .
    bolt is still sticky once reinserted.
    get new bracket bolts and brake grease use breaker bar to break bolts and u should b straight
  1. Best Caliper Paint?
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2010, 02:38 AM
  2. Caliper Color
    By Kenny75k in forum Brakes/Suspension/Chassis
    Last Post: 02-12-2009, 09:51 PM
  3. caliper bracket
    By gotboost3 in forum Brakes/Suspension/Chassis
    Last Post: 02-11-2009, 08:44 PM
  4. Caliper color
    By BankRupt in forum Visual/Body Modifications
    Last Post: 02-05-2009, 10:51 PM
