Thread: Tire/suspension/sway bar ??
Results 1 to 3 of 3
  1. #1 Tire/suspension/sway bar ??
    Wake Forest, NC
    I have a 99 GP GT w/130,000 miles. Recently i have noticed a bad vibration when i hit about 40mph and up, so i jacked the car up and noticed a 6'' area of wires showing through the tire on the passenger on the inside. It also got me to thinking that the wires broke and that's half the problem. I was reading somewhere on the forum to take it to a shop and get a free suspension check so i did, They called me over a showed me that the sway bar ends were in bad shape (not the end links). My question is would a faulty sway bar cause the car to vibrate that bad, I noticed when on the freeway if there was a slight turn to the left or right it would stop vibrating. Any input would be great, I'm also looking to do some suspension upgrades.
  2. #2 Re: Tire/suspension/sway bar ??
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Swaybar didnt cause that, a bad alignment did. The swaybars are knows to rust through on the ends though and should be replaced.
  3. #3 Re: Tire/suspension/sway bar ??
    Jan 2009
    Tallahassee, FL
    You had the banding showing on the tires? That was deffinately the cause as well as an anlignment/tires out of balance. An anlignment and new tires will be good. If you get new swaybars just go ahead and get the GMPP swaybars.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  1. Help on Sway bar
    By Vetolien in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2009, 12:08 PM
  2. Energy Suspension Suspension Parts
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 03-09-2009, 10:25 PM
  3. tire rack ? about this tire
    By GTPJOE90 in forum Tires & Wheels
    Last Post: 03-09-2009, 09:12 PM
bar
