Thread: SSC lowering springs
Results 1 to 20 of 24
  1. #1 SSC lowering springs
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    does anybody have SSC lowering springs in there car. i was wondering how the ride is?
  2. #2 Re: SSC lowering springs
    GT Level Member Clar2478's Avatar
    Nov 2008
    Idaho
    mine rides fine.
    Call me Brad
    '06 GT: Just a few mods here and there.
  3. #3 Re: SSC lowering springs
    Grayslake
    does it still feel like it stock
  4. #4 Re: SSC lowering springs
    Donating Users
    Plainfield, IL
    alot of people complain the SSC drop is too subtle id go eibach's 1.5 drop is perfect...
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  5. #5 Re: SSC lowering springs
    Jan 1970
    Maquoketa, Iowa
    I have SSC's with kyb gr2 struts and I think it rides worse than a truck. I also blew two axles out from the car being too low and the geometry of the axle/transmission is messed up after lowering it. I can't go with shorter dogbones and I don't want to go with spacers. Don't know what Im going to do yet, might go back to stock springs but I have a few things left to try. Its not that I dont like the look and can deal with the ride, I just don't want to be replacing axles every month with this new setup.
  6. #6 Re: SSC lowering springs
    Feb 2008
    Quote Originally Posted by FoSHO99 View Post
    You may only be left with spacers as an option.
    He is correct, though. Lowering your car does throw off the axle geometry. You will have to do something to try and correct that.
    I have SSC's and shorter dog bones and the car rides quite well with my crappy old GR2's. I will definitely suggest that you get a good set of struts when you lower it. AGX is what I would recommend if you can pony up the cash for them.
  7. #7 Re: SSC lowering springs
    i dont like SSC just because they dont lower the car enough from what ive seen. i ride eibachs and the ride is decently rough, but it makes up for it by looking killer. id say my car is lowered a good 2" compared to a stock GP.
  8. #8 Re: SSC lowering springs
    Jersey
    i don't really like my ssc's let me know if you want to buy them, i just got mine on in January.
    16' wrx sti- stock
  9. #9 Re: SSC lowering springs
    Grayslake
    so would eibach spring and kyb gr-2 struts be better than ssc and gr-2?
  10. #10 Re: SSC lowering springs
    they would be about the same, but eibach would lower the car slightly more.
  11. #11 Re: SSC lowering springs
    Grayslake
    have you had any problems with lowering your car yet
  12. #12 Re: SSC lowering springs
    besides the acceleration vibration that i half-assed solved with shorter dogbones and the rough ride? nope.
  13. #13 Re: SSC lowering springs
    Grayslake
    alright thanks.
  14. #14 Re: SSC lowering springs
    zalma mo.
    hey i'm getting ready to lower my gp, thinking about going with eibach, i see you guys talking about spacers and shorter dogbones where can i get them and can i use them together? thanks
  15. #15 Re: SSC lowering springs
    shorter dogbones? drill a new hole in your stock ones 3/4" back center to center and then cut the fronts off. or get another set from the junkyard. all the ones that are sold are too short.
    spacers? gotta find vinnie for the good ones. they are $50 a set and go in the motor mounts to raise up the motor a little.
    you get one or the other. depending upon your mods and where your headers/exhaust sits, you might not be able to use the spacers (like me).
  16. #16 Re: SSC lowering springs
    zalma mo.
    thanks, I havent lowered a front wheel drive car so i dont know what to expect.
  17. #17 Re: SSC lowering springs
    Nov 2008
    Idaho
    Why do you say they're too short?
    Call me Brad
  18. #18 Re: SSC lowering springs
    the ones that are sold are most likely montana dogbones. they are 1" shorter than ours and that is too short. it causes your headers to hit the radiator fan shroudings and possibly the downpipe being too close to the underside of the car.
    that 1/4" does a lot.
  19. #19 Re: SSC lowering springs
    Nov 2008
    Idaho
    well...I guess I'm gonna have to find out if my headers will fit this summer or not. Thanks
    Call me Brad
  20. #20 Re: SSC lowering springs
    SE Level Member 08GrandGXP's Avatar
    St Paul, MN
    I have a ? Did any of you replace your pogo washers when you lowered your ride!?
    also did you find it hard to install the SSC springs and do you have any recomendations on how to do them a little easier!?
  1. Lowering Springs
    By caseycour in forum Brakes/Suspension/Chassis
    Last Post: 07-27-2009, 09:21 PM
  2. lowering springs
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 03-22-2009, 02:16 AM
  3. lowering springs
    By ibanez0110 in forum Brakes/Suspension/Chassis
    Last Post: 11-27-2008, 10:22 PM
  4. lowering springs help
    By philip09 in forum Brakes/Suspension/Chassis
    Last Post: 04-03-2008, 05:50 PM
