Thread: Re-Doing Suspension
Results 1 to 3 of 3
  1. #1 Re-Doing Suspension
    SE Level Member GPBoy00's Avatar
    Minnesota
    I'm about to re-do my suspension. As of now I have Eibachs on KYB GR-2's and they didn't last long at all. I installed them myself and loved it at the beginning. Now I need to replace the struts and already have a set of AGX's to go on, and also the GMPP front and rear sway bars with Moog end links fron and rear. I just want to know if there is any difference between the Monroe and any other strut top mounts? Also, when I did my suspension a few years back I replaced both front and rear strut top mounts, I'm for sure going to replace the front ones since they do have bearings in them, but should I replace the rear ones or should they be fine? Do the camber adjustment bolts help out with alignment? On to the sway bars. What are the benefits of flipping the front one? What is the best way to replace the front one without throwing tools and cussing, if you know what I mean since I have heard it can be a PITA?
    I think that's all I need to know right now, but if I have anymore questions I will ask. Thanks in advanced for the help.
    ~Nick~
    2000 Pontiac Grand Prix GTP Daytona 500 Pace Car Replica.
  2. #2 Re: Re-Doing Suspension
    Dec 2008
    Lawndale, CA
    I have the monroe mounts. They have been fine so far. You can find some OEM replacements on rock auto. You will be fine in just replacing the fronts. I did not need the camber bolts whne I lowered mine. But eibachs sit much lower than the GMPP springs. I also did not have to flip my sway bar. Some do it for clearance issues. It was a pain to remove it. Other than that you should be good to go.
  3. #3 Re: Re-Doing Suspension
    Banned - Busted For Scamming
    Feb 2009
    did my front one in about 1hr total by myself in the parking lot lol... i didnt have to flip mine either
  1. Energy Suspension Suspension Parts
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 03-09-2009, 10:25 PM
  2. Suspension
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 02-10-2009, 08:30 AM
  3. Suspension Help
    By 04gpking85 in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2008, 08:41 PM
  4. Suspension 04 GTP
    By Keet04GTP in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2008, 11:12 AM
  5. Need some help with my suspension please!!
    By dementeddj in forum Off Topic Discussion
    Last Post: 02-11-2008, 07:12 PM
