Thread: play in rear passenger wheel even after new moog bearing
Results 1 to 14 of 14
  1. #1 play in rear passenger wheel even after new moog bearing
    Jul 2017
    macomb mi
    hey everyone i noticed a play in my rear passenger wheel when holding the wheel at the 12 and 6 position and assumed wheel bearing so i changed it then a day later the play came back. i do get a slight sway when going highway speeds and hitting certain parts of the road that have grip ridges for increased traction in rain. just wondering what else the play could possibly be i shook the trailing arm, sway bar, and both lateral links and all were SOLID any suggestions? could the wheel bearing have come loose in a day do i need to re-tighten.
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  2. #2 Re: play in rear passenger wheel even after new moog bearing
    Oct 2014
    portland oregon
    I guess it's possible but moog is pretty good.. if the wheel was tight when you replaced it and now it's not then I would say you got the 1 on 1000 pos lol.
    Online order? Even if not call email or go to the parts store and give an a peice of your mind
    Sent from my SM-N920V using Tapatalk
  3. #3 Re: play in rear passenger wheel even after new moog bearing
    Apr 2014
    commerce twp,mi
    04-08 Grand Prix - Basic Lateral Link Check - YouTube
    how are the tires wearing? could need an alignment. if you have play and its not in the bearing, it could be a bushing
    08 grand prix NA3800
  4. #4 Re: play in rear passenger wheel even after new moog bearing
    Jul 2017
    macomb mi
    tires are wearing as expected very very minimal camber wear but I have it set to about 2 degrees of camber so it should happen. average non-car person wouldn't be able to spot the wear even if you told them. also lateral links are tight and fairly new BMR branded ones only about a year and a half old. I did get the moog bearing from the local advanced auto so I could maybe see if its bad? its just a chore since I have longer studs in the rear due to a spacer needed for clearance of the trailing arm so swapping those out takes me longer than replacing the actual hub. my front alignment is toast and plan on getting an alignment Wednesday and would like to have this issue fixed in the rear as well before doing so.
  5. #5 Re: play in rear passenger wheel even after new moog bearing
    GT Level Member mguzzo's Avatar
    Buffalo NY
    obvious question - do your lug nuts allow the wheel to tighten flush to the hub face?
    do you get movement at 3 and 9 as well?
    If you take the wheel off, does the hub still have play?
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  6. #6 Re: play in rear passenger wheel even after new moog bearing
    Jul 2017
    macomb mi
    its weird I checked the 12 and 6 and I couldn't find any play this morning even though it was clearly noticeable last night and I checked the 3 and 9 position both last night and this morning seemed pretty solid to me and the hub doesn't have play when the wheel is off I assumed that was just due to leverage and the fact that I really cant crank on it with the 3 or 4 in diameter the hub has? im not sure if its completely flush to the hub face but just looking from the car being on the ground it seemed pretty flush and its the same setup on the other rear tire and there are no issues there. also I've been driving it 40+ miles for the past few days so its doesn't seem to be in critical condition... yet
  7. #7 Re: play in rear passenger wheel even after new moog bearing
    Jul 2017
    macomb mi
    not sure if I was seeing things or not but when there was play the brake caliper seemed to compress and decompress with the play? like the brake rotor was forcing it to? could the rear knuckle have cracked or something crazy like that? Michigan roads plus construction is a beat down right now and ive hit a few cringy potholes this year but I just assumed the front would take the damage over the rear due to increase weight and the fact the front gets pushed into the hole while the back gets pulled into it
  8. #8 Re: play in rear passenger wheel even after new moog bearing
    Apr 2014
    commerce twp,mi
    michigan roads and construction are a beat down??? it cant be!
    it is quite insane. idk what its like out around macomb(the twp) way,although i hit m59 to the east coast and go up to port huron once a week and it can be "interesting"( read, PITA). i feel sorry for anyone having to do the 75/m59 mess on a daily basis,too. dont go through there at rush hour(s) but can only imagine.
    im really not sure whats goin on there but will be following this thread.
  9. #9 Re: play in rear passenger wheel even after new moog bearing
    Jul 2017
    macomb mi
    lol that's literally my daily route the m59 to hall road change over is like nothing I ever seen right now either and im too stubborn to have A/C so ive done a lot of unnecessary sweating haha
  10. #10 Re: play in rear passenger wheel even after new moog bearing
    Apr 2014
    commerce twp,mi
    looks like fun! heading back west in the evening-rush hour.welp, i think its hourS now. seems any time between 4 and 7-all the traffic heading east backed up- sometimes its been 3 miles of backup.
    i think it would still be better in that than tryin to run either the I275 hundred or 696hundred any time of day,though. those 2 expressways are friggin nuts! apparently 90 is the new 70.
  11. #11 Re: play in rear passenger wheel even after new moog bearing
    Jul 2017
    macomb mi
    90 is the new 70 much better than 40 is the new 70
  12. #12 Re: play in rear passenger wheel even after new moog bearing
    If you had play only 12 to 6 and not 9 to 3... it wasn't a wheel bearing. My first guess would be to check the strut bolts to the knuckle.
  13. #13 Re: play in rear passenger wheel even after new moog bearing
    Jul 2017
    macomb mi
    I'll have to check when I get home I'll feel stupid that I listened to the shop that said it was a wheel bearing when it is just the bolts could it possibly be a cracked knuckle as well? Or do they not crack? Only reason I'm asking is because those bolts havent been touched for 3 years it be odd for them to come loose now but could be possible
  14. #14 Re: play in rear passenger wheel even after new moog bearing
    Jul 2017
    macomb mi
    strut bolts were tight rechecked everything else and they seemed good but I really tightened down all the lug nuts and one of them had a feeling like the stud was not all the way seated issue has seem to gone away just amazed I drove it so far if that was the issue
  1. front passenger wheel has play???
    By elejes in forum General Tech Discussion
    Last Post: 04-05-2014, 08:10 PM
  2. need help removing rear wheel bearing hub assembly
    By tiedye in forum Off Topic Discussion
    Last Post: 04-26-2011, 07:15 AM
  3. Rear hub/wheel bearing..
    By oneil.GTP in forum Brakes/Suspension/Chassis
    Last Post: 11-20-2010, 11:04 PM
  4. Rear Wheel Bearing
    By codyc in forum Brakes/Suspension/Chassis
    Last Post: 05-04-2010, 01:25 PM
