Youtube the repairs if you want a hands on point of view, it's been covered many times over.
Anything that comes up as a grand prix, regal, park ave, impala, monte carlo is the same body platform and the repair is pretty much exactly the same.
Cliff notes, remove wheel, remove caliper, remove rotor, remove axle nut for fronts, remove 3 bolts holding bearing to knock, smack it off with a hammer, replace bearing and install in reverse order.
Axle nut torque spec is 118ft lbs, lug nuts are 100ft lbs. I use the german spec on everything else.
Anything with a good warranty for bearings work. SKF and MOOG bearings are great buys.
ok thanks for help i wil do my research is the front ones a pain or not im never done this before im sure i could give a try
