Thread: Parking brake cable connector broke
Results 1 to 5 of 5
  1. #1 Parking brake cable connector broke
    Jan 2018
    Canada
    Hi all,
    The car is a 2007 Pontiac Grand Prix base 3800. I went to use the parking brake and something snaped. I had a look around and you’ll see in the pictures here like the adjuster casing from the front cable broke. I managed to pull it off the cable. I would think that the mechanism is repairable please. As in could I buy just the part that broke. I did have a look for the part online, but I wasn’t able to pinpoint. Otherwise the cables are in decent shape, the two rears ones were changed. My guess is that I would have to disconnect the front cable from it.
    https://drive.google.com/open?id=1Ll...5kVPE-ocmgX2cW
    https://drive.google.com/open?id=1ID...lYf_sUzTDrufNo
    https://drive.google.com/open?id=1_-...ul_qhzVkc1KgFd
    https://drive.google.com/open?id=149..._kgstZo48ixbru
    https://www.amazon.com/ACDelco-25537...ke+adjuster+gm https://www.amazon.com/dp/B00EFCA9K0...547419901&sr=3
    https://www.amazon.com/dp/B007Q17AIG/ref=psdc_4543050011_t1_B00EFCA9K0
    This one I found is not a match online, but it really does look similar
    https://www.amazon.com/dp/B00EFCA9K0..._t3_B0049HITEE
    Please and thank you
  2. #2 Re: Parking brake cable connector broke
    Pennsylvania
    That cable looks pretty messed up on the ends. I haven’t looked at mine in a long time, though... I’ll take a look at the setup when I get home.
    I’m having a hard time visualizing what that would look like before it was broken... and it looks like you’re showing pictures back between the rear wheels?
    It also looks like the adjuster is intact (the threaded part), though absolutely wrecked by rust. If that’s what’s broken, you’ll be better off just buying a new rear right cable. It comes with it... I’d do both sides while I’m back there.
    Like I said, it’s been years since I’ve actually looked at mine, so I’ll check it in a couple hours and get back.
  3. #3 Re: Parking brake cable connector broke
    Jul 2010
    Coquitlam,BC,Canada
    Found a pic on the web of an 04......
    Should be easy to swap out, if you can get that part.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Parking brake cable connector broke
    Pennsylvania
    Yeah that part is replaceable, but honestly it might be a real fight with how rusty they are.
    Even if you hold off til the weather improves a bit to tackle it, you should be able to do it.
  5. #5 Re: Parking brake cable connector broke
    Nov 2013
    pittsfield ma. 01201
    Just did mine all parts available did not cost much got mine at advance auto
  1. Throttle cable plastic tab broke!
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2014, 05:58 PM
  2. Putting the parking brake cable on the rear caliper
    By Fahrenheit in forum Brakes/Suspension/Chassis
    Last Post: 10-09-2013, 03:32 PM
  3. parking brake broke
    By ionroller in forum General Tech Discussion
    Last Post: 01-03-2009, 11:10 AM
  4. Broke my shifter cable
    By nlinesk8s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-30-2008, 09:33 PM
  5. I think I broke the parking pin !
    By Meemperor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-03-2008, 12:30 AM
