Thread: slotted rotors
Results 1 to 7 of 7
  1. #1 slotted rotors
    Aug 2017
    Florida
    I am getting ready to do a full brake job pads, rotors, maybe calipers if I can find a good deal. I see alot of drilled rotors and lots of people upgrading to them. Years ago when drag racing competitively I was always told by my crew chief slotted or solid rotors have more material for a better bite and less chance for brake pad materiel build up (some people call it warped) any thoughts?
  2. #2 Re: slotted rotors
    solid blanks work just fine, r1 sells them as well as drilled and slotted. if your going all new you can get them for about 200 for all 4 corners, will be the best damn brakes you ever owned. i promise you that. they will be all i buy from now on.
    pretty much cheaper then any parts store brands made form cheap steel.
  3. #3 Re: slotted rotors
    Aug 2017
    Florida
    sounds good to me thanks!!
  4. #4 Re: slotted rotors
    Nov 2012
    Madison
    Did you check out the big bad brake thread yet?
    Good info. Also Overkill has some good stuff on his GetOverkilled site.
    http://www.grandprixforums.net/threa...d-Brake-Thread
  5. #5 Re: slotted rotors
    Aug 2017
    Florida
    thanks again!!! so much to read lol
  6. #6 Re: slotted rotors
    SE Level Member Garandpa's Avatar
    Oct 2016
    Davisburg, MI
    +1 on R1 brakes. I upgraded all around with drilled rotors and ceramic pads 2 years ago. Stayed with my stock calipers (although I painted them red). Could not be happier.
  7. #7 Re: slotted rotors
    GXP Level Member suitercrew's Avatar
    Oct 2015
    I have to say not to go with "r1 concepts" rotors and pads. When I upgraded to fbody brakes awhile back I got their eline package that came with drilled/slotted rotors and pads. Stopping wise they performed very well, and I was very pleased with the performance. The problem is only approximately 7500miles later the pads are completely gone and need to be changed, on top of that the rotors have a sh*t ton of micro cracks. I understand by choosing drilled rotors your very likely to develop cracks, but multiple cracks on each drill hole not even 10k miles later? Thats just not right. Additionally I ordered the black coated rotors and they sent me standard silver (Not a big deal, but still).
    Before anyone wants to tell me i did something wrong, the calipers were freshly rebuilt with all new hardware, I followed the break in procedure that r1 instructed, and the car is daily driver. It never sees race tracks and I'm the furthest thing from an aggresive barker, I also am not a moron and do not ride the brakes. Pads were worn evenly on inspection as well
    Sent from my LG-H830 using Tapatalk
  1. Used Drilled Slotted Rotors?
    By Confusingboat in forum Tires & Wheels
    Last Post: 09-23-2010, 07:20 PM
  2. Slotted rotors noisy?
    By MBruneaux in forum Brakes/Suspension/Chassis
    Last Post: 03-14-2010, 02:37 PM
  3. Where to get over sized slotted rotors?
    By boomboom in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2009, 11:45 PM
