Thread: front wheel grinding noise per revolution
Results 1 to 7 of 7
  1. #1 front wheel grinding noise per revolution
    Jul 2017
    macomb mi
    hey everyone,
    im having this odd grinding noise on my right front wheel that is only per revolution and if my foot is even slightly on the brake the noise is gone and its very faint can only hear it with the window down and something has to be to the right off me for the noise to ricochet and I can hear it clear. I just changed the hub last night thinking it was the bearing, just did pads and rotors less than 500 miles ago and the fbody calipers and ss brake lines have around 10k miles what could this be. I cant think of anything else that could be wrong?
  2. #2 Re: front wheel grinding noise per revolution
    St. Louis
    Check the dust shield. I'd bet it's bent and is touching ever so slightly. Quite common even though everyone swears they didn't bend it.
  3. #3 Re: front wheel grinding noise per revolution
    i had the same issue. dust shield was rubbing at the bottom best guess it bend when i was stuck in deep snow.
  4. #4 Re: front wheel grinding noise per revolution
    Jul 2017
    macomb mi
    ill check it out tonight sounds too easy though lol but I wanna say I don't remember there being a dust shield on the front wheels just the back but ill take a look tonight and let you guys know hopefully you're right and I was just blind thanks for the input
  5. #5 Re: front wheel grinding noise per revolution
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    On the 97-03 GP's, in the front, there is no dust shield, aka backing plate. However, it's likely the little arm that holds the ABS sensor. Probably touching the rotor.
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  6. #6 Re: front wheel grinding noise per revolution
    there is a shield, not a full one as if the caliper was on the back of the rotor like a lot of cars have it. but where the abs plug part of it is what is most likely the rub.
    that part was rubbing on mine, like i said, stuck in the snow, heard it once spring time came around.
    it tends to get bent when doing a full brake job, or a hub, cause it comes off when doing a hub. mystery stuff happens then lol
    turn the wheels to the side you hear it from, lay down and look at the bottom of the rotor where that plug is, with a screw driver pry it back some.
    if this has been going on for some time now you might even see a line scored in the rotor, like i had on mine.
  7. #7 Re: front wheel grinding noise per revolution
    Jul 2017
    macomb mi
    That plate was close but not touching bent it back a little but also noticed the pad shims had so wear on them as if the rotors diameter was too large for them if you can imagine lol so I tried to bend them in as much as I could and grinded the outside of the rotor just a bit so hopefully that will take care of it any other ideas or probably just grind the rotor more to bring down the diameter
  1. Front Grinding Noise
    By Axlebroskii in forum General Tech Discussion
    Last Post: 06-05-2013, 03:06 PM
  2. Front wheel noise
    By Skip77j in forum General Tech Discussion
    Last Post: 04-06-2013, 08:49 PM
  3. Grinding noise when wheel turned sharply slowing down
    By steeck1 in forum Brakes/Suspension/Chassis
    Last Post: 12-13-2011, 04:19 PM
  4. 04 gt grinding noise right front
    By pmusial in forum Introductions/Noob Questions
    Last Post: 09-15-2010, 07:20 PM
  5. Right-Front Grinding Noise
    By cowmilker08 in forum General Tech Discussion
    Last Post: 06-07-2010, 01:36 PM
