#1
Weird movement while braking
This has been happening for a while now. Been having transmission issues that have recently been fixed so I'm back to driving it again.
I have done the f body front brake mod and it didn't help or changed a thing.
When braking it has a tendency to pull to the left. It's got new rotors, pads, calibers, and hoses so I know it's not form them.
While driving it rides smooth and doesn't pull to one side or the other so I know it's not an alignment issue. It only happens when braking.
Any ideas?
05 Grand Prix - stock, 98 Trans Am - Heavy Modified, 00 Firebird Vert
#2
Re: Weird movement while braking
03-21-2018
Are the guide pins lubed and sliding properly? Other than that could be a stuck caliper. Notice more wear on the brake pads on one side vs. the other?
#3
Mis-matched tire sizes or brands ? Uneven inflation ? Brakes totally bled ? An off camber wheel might still allow it to drive straight, while making it pull under braking. Toss a $69 alignment at it, couldn't hurt.
For the record : I am NOT a naked meth-head who shoves rocks up my butt.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#4
Brake pads, rotors and pins all new(ish), calibers were both good. I took them off my Trans Am when I did the C5 upgrade on it. It did this before the brake upgrade.
I'm thinking it's the suspension maybe the upper and lower a arms after talking with my son. We had to replace both of them a while back and he thinks it may have started after we replaced them. So this weekend I plan to get it up on stands and do another look over.
#5
Well found the issue. Both inner and 1 outer tie rods bad, both control arms were toast.
Spent all day fighting the tie rods but got it done. No more death wobble but alignment is way off.
#6
smws6ta
All that slop and it still didn't pull to one side ?? Must have been plenty of free play in your steering wheel ?
#7
Oh it did when applying the brakes. It would pull to the left in the beginning but in the last week or two it began to wobble instead. I'll post a pic later.
#8
04-03-2018
Never a bad thing to put the car up and check suspension etc.
Alignment is done and back to being safe again. 1st time in a long time driving it that I enjoyed driving it.
#10
smws6ta
No more Pucker Factor, eh ?
