Thread: Weird movement while braking
Results 1 to 10 of 10
  1. #1 Weird movement while braking
    Jan 2015
    Alabama
    This has been happening for a while now. Been having transmission issues that have recently been fixed so I'm back to driving it again.
    I have done the f body front brake mod and it didn't help or changed a thing.
    When braking it has a tendency to pull to the left. It's got new rotors, pads, calibers, and hoses so I know it's not form them.
    While driving it rides smooth and doesn't pull to one side or the other so I know it's not an alignment issue. It only happens when braking.
    Any ideas?
    05 Grand Prix - stock, 98 Trans Am - Heavy Modified, 00 Firebird Vert
  2. #2 Re: Weird movement while braking
    St. Louis
    Are the guide pins lubed and sliding properly? Other than that could be a stuck caliper. Notice more wear on the brake pads on one side vs. the other?
  3. #3 Re: Weird movement while braking
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Mis-matched tire sizes or brands ? Uneven inflation ? Brakes totally bled ? An off camber wheel might still allow it to drive straight, while making it pull under braking. Toss a $69 alignment at it, couldn't hurt.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  4. Likes BANDIT liked this post
  5. #4 Re: Weird movement while braking
    Jan 2015
    Alabama
    Brake pads, rotors and pins all new(ish), calibers were both good. I took them off my Trans Am when I did the C5 upgrade on it. It did this before the brake upgrade.
    I'm thinking it's the suspension maybe the upper and lower a arms after talking with my son. We had to replace both of them a while back and he thinks it may have started after we replaced them. So this weekend I plan to get it up on stands and do another look over.
  6. #5 Re: Weird movement while braking
    Jan 2015
    Alabama
    Well found the issue. Both inner and 1 outer tie rods bad, both control arms were toast.
    Spent all day fighting the tie rods but got it done. No more death wobble but alignment is way off.
  7. #6 Re: Weird movement while braking
    May 2016
    Rouge Island
    Quote Originally Posted by smws6ta View Post
    All that slop and it still didn't pull to one side ?? Must have been plenty of free play in your steering wheel ?
  8. #7 Re: Weird movement while braking
    Jan 2015
    Alabama
    Oh it did when applying the brakes. It would pull to the left in the beginning but in the last week or two it began to wobble instead. I'll post a pic later.
  9. #8 Re: Weird movement while braking
    Never a bad thing to put the car up and check suspension etc.
  10. #9 Re: Weird movement while braking
    Jan 2015
    Alabama
    Alignment is done and back to being safe again. 1st time in a long time driving it that I enjoyed driving it.
  11. #10 Re: Weird movement while braking
    May 2016
    Rouge Island
    No more Pucker Factor, eh ?
  12. Likes smws6ta liked this post
  1. Engine noise/movement 05 GP
    By Taprot in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2016, 12:44 AM
  2. Engine movement
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 10-06-2014, 01:48 AM
  3. Noise on first movement of car and when braking on slick surface
    By ImColeTrickle in forum General Tech Discussion
    Last Post: 02-01-2012, 11:21 PM
  4. cv shaft and joint movement
    By Scottydoggs in forum General Tech Discussion
    Last Post: 09-24-2011, 09:16 AM
  5. Movement in the other direction!
    By GPGT08 in forum Tires & Wheels
    Last Post: 07-01-2008, 05:06 PM
