Thread: Front end rattle help
Results 1 to 9 of 9
  1. #1 Front end rattle help
    Mar 2013
    canada
    Need some help, rebuilt the car last year, 02 GTP, new complete strut assemblies all around, brakes, etc. Now a year later rattling on the front end it seems, checked and found sway bar cracked where it bolts to end link and broke on driver's side at the bend. New dorman sway bar and end links, still rattles. So new brake hardware except for the caliper bolts which were in good shape, new rubber boots and clips, still rattles at slow speed over bumps. Everything else is tight, have had all 4 wheels off multiple times and I'm at a loss as to what the hell is causing this.
  2. #2 Re: Front end rattle help
    check the sub frame bolts.
  3. #3 Re: Front end rattle help
    Mar 2013
    canada
    How many are there, just the 2 near the sway bar or more hidden away?
  4. #4 Re: Front end rattle help
    two up front two by the rack.
  5. #5 Re: Front end rattle help
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Could be sub-frame bushings.
    Link: The Clunk is Over
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  6. #6 Re: Front end rattle help
    Mar 2013
    canada
    Would the sub frame bushings cause the metallic like rattle like loose calipers?
  7. #7 Re: Front end rattle help
    Mar 2013
    canada
    Well all 4 sub frame bushings look to be in decent shape, no tearing or rips in the rubber and everything is tight. Guess I will have to get in trunk and have someone drive around and see if I can further pinpoint where the noise is coming from.
  8. #8 Re: Front end rattle help
    St. Louis
    Have you ever replaced the control arms and ball joints?
  9. #9 Re: Front end rattle help
    Mar 2013
    canada
    Yes, last year I rebuilt with new control arms, brakes, tie rod ends, ball joints and cv joints. Car was written off and sat for a couple years until I had the time and money to get it back on the road. The only thing I have not replaced are the caliper bolts and caliper bracket bolts.
  1. Steering wheel buttons: rattle rattle rattle rattle rattle rattle!
    By Bugsi in forum General Grand Prix Discussion
    Last Post: 11-04-2016, 03:52 PM
  2. Rattle from the front
    By gagt3100 in forum General Tech Discussion
    Last Post: 11-04-2012, 03:29 PM
  3. Rattle from front driver tire?
    By mdwstgt in forum Tires & Wheels
    Last Post: 06-18-2012, 02:32 PM
  4. Rattle on drivers front side
    By boneman29 in forum General Tech Discussion
    Last Post: 04-09-2011, 05:03 PM
  5. Front Caliper Rattle
    By tdaye in forum General Tech Discussion
    Last Post: 07-20-2009, 07:14 AM
