Thread: Ball joint is stuck
Results 1 to 20 of 20
  1. #1 Ball joint is stuck
    Jul 2013
    Phoenix
    Last night (for about 5 hours) I was stuck trying to get my front Driver ball joint to pop loose from the knuckle (I'm trying to change a bad axle, way too much car shaking around!)
    I'm totally flummoxed, I tried hitting with hammers, jumping (literally) on prybars, smashing the living Schtick out of a pickle fork and all to no avail. The silly ball joint separator tool I borrowed from Autozone was too short to fit into the space behind the knuckle and wouldn't sit on the stud.
    If the stud is seized into the knuckle what do I do to get it out that I haven't already tried? Is there a better tool? If I just changed the control arms (they are 15 years old...) would that give me more room at the knuckle end? Do I need a bigger hammer?
    Man, these past 2 months have had way too many repairs
    Sincerely,
    Still covered in grease and tired of repairs
  2. #2 Re: Ball joint is stuck
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    BFH
  3. #3 Re: Ball joint is stuck
    you need to put a long bar through the lca, then under the frame, then stand on it, then hit the lca @ the ball joint area with a hammer.
  4. #4 Re: Ball joint is stuck
    Buffalo
    Use the jack in special way
  5. #5 Re: Ball joint is stuck
    GTP Level Member buickman104's Avatar
    NYC
    https://www.amazon.com/GearWrench-39...oint+separator
    Been getting ball joins off with a hammer and pry bar for years. Until I just gave up and got this...
    Best $20 I spent.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  6. #6 Re: Ball joint is stuck
    St. Louis
    I've had to heat the knuckle with a torch where the ball joint goes through the knuckle, and then use a good sized Ford wrench on it and it finally popped loose. Keep the nut just to the top of the ball joint threads so you get a good hit on it without mushrooming the end of the joint.
  7. #7 Re: Ball joint is stuck
    Jul 2013
    Phoenix
    The separator didnt slide on far enough to get the ball joint stud on the inside of the knuckle, the pry bar, with me (230 lbs) jumping (literally) on it and wifey smacking the knuckle, didn't budge and I don't have a torch. Im considering taking the knuckle off the strut so I can pull it down and out of the way. All I want is the stupid CV Axle anyway!
  8. #8 Re: Ball joint is stuck
    Jul 2013
    Phoenix
    Did that, big bar and big hammer = didn't let go
  9. #9 Re: Ball joint is stuck
    Jul 2013
    Phoenix
    Quote Originally Posted by CrazyGuy03 View Post
    Even tried some of those shenanigans!
  10. #10 Re: Ball joint is stuck
    Air hammer.
  11. #11 Re: Ball joint is stuck
    Buffalo
    Hmm yeah. Worse case scenario I use the jack to lift he knuckle and tap the joint out.
  12. #12 Re: Ball joint is stuck
    SWPA
    Go buy a MAP torch. It's come in handy numerous times already since I don't have an oxy/acetylene setup.
  13. #13 Re: Ball joint is stuck
    Quincy, Mass
    I just got used knuckles off eBay, my axel was also stuck in the bearing. Bfh did nothing. I was replacing the control arms anyways so the car was just down a few days while I waited for parts to arrive.
    No more GP 04 Impala SS Indy:
  14. #14 Re: Ball joint is stuck
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    If all you're wanting is to remove the cv axle, I actually found it's easier just to disconnect the arm at the subframe, remove the axle nut and pry on the bushings until the arm comes free. Saves a bunch of time and frustration.
  15. #15 Re: Ball joint is stuck
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I have had to beat the hell out of the knuckle and arm its self on many occasions While having someone push down on the 4' snap on pry bar and then I had to continue beating it. Heat will help also. You can also pull the two control arm bolts and pull it out that way like said above ^.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  16. #16 Re: Ball joint is stuck
    Jul 2013
    Phoenix
    Which is the preferred method: pulling the knuckle off the strut or pulling the control arm off the sub frame?
  17. #17 Re: Ball joint is stuck
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Subframe, It will allow you to pull the control arm out enough to remove the axle. If you just unbolt the strut bolts you have the same situation of not being able to pull out the control arm because it is still connected at both the ball joint and subframe
  18. #18 Re: Ball joint is stuck
    Jul 2013
    Phoenix
    Thanks for the advice everyone. I'll get it done this week(end) and let everyone know how it went!
  19. #19 Re: Ball joint is stuck
    Quincy, Mass
    And if you unbolt the strut your alignment will be off. If you are already getting and alignment then no biggie.
  20. #20 Re: Ball joint is stuck
    Jul 2013
    Phoenix
    Thanks for all the help folks! Old axle is out (definitely had a bearing that was shot...little metal rods all in the housing) new axle is in an no more shaking! Thanks!
  1. How to get ball joint off and new one on
    By Bigheadedon in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-09-2013, 03:07 PM
  2. 97 ball joint
    By jc71corvette2 in forum Introductions/Noob Questions
    Last Post: 10-02-2013, 11:25 AM
  3. Ball joint help
    By geetee in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2011, 05:23 PM
  4. ball joint maybe?
    By Jakegday in forum General Tech Discussion
    Last Post: 10-04-2009, 11:15 AM
  5. Ball joint-What do ya think?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 07-25-2008, 11:32 AM
