Thread: Noticible wobble in the front end when slowly coming to a stop
Results 1 to 3 of 3
  1. #1 Noticible wobble in the front end when slowly coming to a stop
    SE Level Member Bowslingin's Avatar
    Oct 2017
    Kansas
    I've noticed recently that it just started doing this, replaced rotars and brake pads. Sway bar and CVs, my guess is that the tie rod ends and bushings needs replaced.
  2. #2 Re: Noticible wobble in the front end when slowly coming to a stop
    St. Louis
    That or control arm bushings/ball joints. Get it up in the air and grab the tire at 3 and 9 and push/pull to see where the play might be. If it is control arm bushing or ball joint just get yourself an entire new control arm as they come with new ball joints ready to go. Just grease them and install.
  3. #3 Re: Noticible wobble in the front end when slowly coming to a stop
    You'll want to jack up the front end and check for play.
    With the steering wheel not locked (key in the ignition) try to check for play at 9 and 3 to check for tie rod end movement. You can grab the front of the tire and check for ball joint play and 12/6 would be wheel bearings.
  1. Random stall when coming to a stop
    By bonerjamz03 in forum General Tech Discussion
    Last Post: 09-11-2017, 03:29 PM
  2. rpm drops when coming to a stop
    By bocou92 in forum Engine
    Last Post: 08-28-2014, 08:58 AM
  3. Trouble downshifting when coming to a stop.
    By wytmyk420 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-31-2011, 05:04 AM
  4. front end wobble
    By newmod in forum Brakes/Suspension/Chassis
    Last Post: 12-30-2011, 03:08 PM
  5. It's slowly coming together... (lots of pics 56K)
    By Smokin2000gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2008, 04:42 PM
