Thread: rear suspenison issues.
Results 1 to 13 of 13
  1. #1 rear suspenison issues.
    May 2008
    McHenry IL
    OK hello every1 when i go over big bumps my car ONLY on the RR the tire will hit the fenderwell and start to cut the tire. so tomarrow at school im doing rear shocks on my car. i got gabriel Gas ultra XX shocks. my question to every1 is how long does it take to replace the shocks? there anything else i have to replace that will get broken or anything in the process ??? thanks guys.
  2. #2 Re: rear suspenison issues.
    TDCRacing
    Guest
    You may want to return those ''shocks''. We have struts on our cars. If you did not get the full assembly then you will only replace the strut and will have to reuse the spring on you're old strut. You will need a spring compressor.
  3. #3 Re: rear suspenison issues.
    May 2008
    McHenry IL
    im doin it at my college we have it all and yes sorry i ment struts h\im used to replacin our truck stuff lol soz i mean like is there anything common that breaks in the process of dissassembling that can become broken or damaged that i need to replace? how long does it usually take to do the rears? my teacher worked for Pontiac for 20 years so.... lol
  4. #4 Re: rear suspenison issues.
    May 2008
    McHenry IL
    BUMP BUMP i got class at 8 til 4 tomarrow im hopin some1 resonds back b4 i leave at 8 thanks every1 i just wanna no roughly how long u think itll take??? i got all the tools a shop can ask for and a knowledge packed instructor how long you think were talkin?
  5. #5 Re: rear suspenison issues.
    Jersey
    the rear's are a big PITA, cuz when you get to the top nuts, there isn't any room. Im sure you will see when you get to it.
    16' wrx sti- stock
  6. #6 Re: rear suspenison issues.
    May 2008
    McHenry IL
    fun.... cant wait..... lol
  7. #7 Re: rear suspenison issues.
    St. Louis Mo.
    You really don't break anything on removing them, unless they are rusted and something breaks cause of that, but for the part its an easy job. But like everyone else, the rears are a PITA for the simple fact that you need a midget to get into the trunk to reach the strut tower bolts. And you will need that midget to be in the truck when you install the new struts in there.
    I always believed when you were replacing struts it is a wise move to go ahead and replace the strut mounts as well. Those take a good beating and if you are replacing them with new struts, you might as well go with new strut tower mounts as well.
    But that is just me
    James Shafer
    St. Louis MO
  8. #8 Re: rear suspenison issues.
    May 2008
    McHenry IL
    got her done yestruday guys it took id say 2 hours and yes i removed my audio stuff from the trunk and lets say the WAY WAY WAY BACK bolts on top sucked lol 2 out of 3 were easy lol overall got her done =]
  9. #9 Re: rear suspenison issues.
    Jan 2009
    Missoula Mt
    I found a 1/2 inch drive socket that is deep enough to get on the top nuts, but short enough to get on that PITA back nut. Its about halfway between a deep well and a regular socket.
  10. #10 Re: rear suspenison issues.
    May 2008
    McHenry IL
    yup thats what i ended up using theyre nice haha
  11. #11 Re: rear suspenison issues.
    Donating Users
    Plainfield, IL
    i had a simliar problem....i just used rubber coil boosters from advance auto..(5$ a piece) and it took care of my butt sagging and bottoming out in the rear my tires are now safe....these are not like the metal spacers people use...these actually allow the spring to still compress just not nearly as fast so they add firmness ive been quite pleased big bumps are not worry for me anymore
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  12. #12 Re: rear suspenison issues.
  13. #13 Re: rear suspenison issues.
    May 2008
    McHenry IL
    these rubber coil boosters where do u put em in at ??? and how do u do it lol never heard of em
  1. HID issues
    By 99prixgt in forum General Tech Discussion
    Last Post: 12-25-2008, 12:27 PM
  2. Idle issues.
    By TDCRacing in forum General Tech Discussion
    Last Post: 09-02-2008, 11:43 AM
  3. idle issues.
    By TDCRacing in forum PCM Tuning
    Last Post: 09-01-2008, 02:21 PM
  4. Just bought her even though she has some issues...
    By heat in forum Visual/Body Modifications
    Last Post: 05-13-2008, 04:32 PM
