Thread: Clamshell spring compressors. Safer?
Results 1 to 9 of 9
  1. #1 Clamshell spring compressors. Safer?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Gonna be picking up tools soon. Are these "better" than the screw down ones?
    HF one
    OTC brand
  2. #2 Re: Clamshell spring compressors. Safer?
    SWPA
    There is danger with any spring compressor. The "safest" one I ever used was a wall mount one, but that being said I have used the "screw down" ones multiple times without an issue.
  3. #3 Re: Clamshell spring compressors. Safer?
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Read the reviews on the HF one B4 U buy.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  4. #4 Re: Clamshell spring compressors. Safer?
    May 2016
    MN
    Thanks. The HF one says to grease the eff out of it, I dunno. I guess I could buy two sets of the screw ones and still save a little money.
    I searched wall mount spring compressors and came across this off ebay. Thoughts? There's some others on that same page.
    http://www.ebay.com/itm/Coil-Spring-...38.m2548.l4275
  5. #5 Re: Clamshell spring compressors. Safer?
    Nov 2012
    Madison
    Get these. If you had 3 it would be ideal.
    Ideally you want them on the diameter line but that isn't going to happen.
    The mounts will be in the way but it is easy to figure out the maximum available smash spots.
    If the new struts have an allen screw end use that and an offset 21 box wrench to tighten the nut.
    Taking the nut off use an impact.
    I bought a set 5 years ago and they have payed off in convenience.
    I can't remember how many times I have used them on my car.
    Grease the threads completely before use. I just use a channellocks to crank them down.
  6. #6 Re: Clamshell spring compressors. Safer?
    Nov 2012
    Madison
    Don't be wimpy just a little careful obviously.
    But really, there is nothing to worry about.
    Keeping the mount and spring in position while loosening the compressors is the biggest janky challenge.
    Do it once and you will be a pro.
  7. #7 Re: Clamshell spring compressors. Safer?
    May 2016
    MN
    Alright. Probably grab some Amazon ones or see if they got loaners in town depending on time frame.
    Looking forward to getting a few things done this storage season.
  8. #8 Re: Clamshell spring compressors. Safer?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I have issues with the screw down ones fitting the rear struts properly. That one from ebay looks promising. not a bad price either
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  9. #9 Re: Clamshell spring compressors. Safer?
    Nov 2012
    Madison
    They fit fine.
    It's the mount in the way that make using a Channellocks easier to turn them.
  1. Increase pneumatic tool air flow on 1/4" NPT compressors and fittings.
    By SaukRapids in forum How To Write-Ups/Tech Tips
    Last Post: 05-12-2017, 09:04 AM
  2. Ac compressors interchangable?
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-19-2015, 06:18 AM
  3. Replies: 2
    Last Post: 12-30-2013, 08:52 PM
