Thread: Brake pedalsurge when turning and braking
Results 1 to 6 of 6
  1. #1 Brake pedalsurge when turning and braking
    Jul 2017
    NE
    New to this forum and have learned a lot since. I have a 04 gtp. Everytime I turn and apply the brakes, it's almost like the abs kicks in and the pedal starts to surge and pulse. You guys are amazing so I hope you can point me in the right direction. I want to build this car but the minor things need to be done first especially those that involve stopping if I'm going to be pushing this car. Thank you all in advance and I hope I get some info from you guys.
  2. #2 Re: Brake pedalsurge when turning and braking
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Check wire harness @ front hubs.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  3. #3 Re: Brake pedalsurge when turning and braking
    best to get it scanned, but it sounds like a bad ebcm.
  4. #4 Re: Brake pedalsurge when turning and braking
    Jul 2010
    Coquitlam,BC,Canada
    Sounds like ABS wiring. As already mentioned, get it scanned; will most likely point you to what corner (wheel) is the culprit.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: Brake pedalsurge when turning and braking
    Nov 2012
    Madison
    Like the guys said, check the front wire harness off the hub.
    They move when you turn. Take off the front wheels and peel back the loom.
    You will probably see your problem right away, besides salt,dirt and moisture.
  6. #6 Re: Brake pedalsurge when turning and braking
    Jul 2017
    NE
    You guys are absolutely fantastic. Will post when I check it out and update
  1. Power Steering Stiff turning wheel Left Normal turning wheel right.
    By AdrianGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2017, 04:39 PM
  2. Brake (!) and (P) light on when NOT braking, only for a few minutes
    By Teancum in forum Brakes/Suspension/Chassis
    Last Post: 05-29-2012, 05:23 AM
  3. Braking Issue
    By juggalette79 in forum Brakes/Suspension/Chassis
    Last Post: 04-24-2012, 08:49 PM
  4. Grinding noise/feel when braking/turning
    By eponine997 in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2011, 02:00 PM
  5. Grinding when braking?
    By LuckyBambu in forum Brakes/Suspension/Chassis
    Last Post: 02-15-2010, 11:54 AM
