Hello everyone.
I have a question, not to recently I replaced the ball joints on my 2008 Pontiac Grand Prix and re lubricated the caliper guide pins and cleaned up the hardware best I could, this includes the control arms and all the bushings, I have also replaced the tie rod ends because the boots split, the struts are only a year or so old and have only 10,000 miles on them and came with lowering springs and new bearing plates, the car also received a transmission overhaul about a couple of months ago, and the rack and pinion was found loose which was making a horrible squeaking noise when i turned the wheel, that was fixed by tightening the bolts up, I have also replaced the sway bar links, and... the car has also been aligned and the exhaust re done, the mechanics didn't notice anything during the alignment or inspection that was off, but after doing the control arms and ball joints, on my first test drive I noticed something and I haven't been able to fix the issue.
Question is I am getting a clunking noise now, when I drive forward or back up the car makes sort of a "clunk clunk clunk." noise, also when braking I have noticed sometimes it will also clunk a little, I also noticed the car pulls slightly to the left when breaking.
I suspect it might be some of the brake hardware because some of the hardware on the passenger side front was pretty well warn out and I will be replacing that next break job very soon, the pads also need replaced, the bushings on the guide pins don't look too good, one of the bushings on the passenger side is literally missing, I know this is in place to reduce any noise that might be had during braking, but I am not sure that will cause the noise I am experiencing.
what do you guys think?
