Thread: Tire rubbing sound.
Results 1 to 9 of 9
  1. #1 Tire rubbing sound.
    GT Level Member Jnibbs24's Avatar
    Sep 2015
    Seattle
    Ok, so I've had this issue going on for a bit, not sure what it is. Sounds like my tire is rubbing going less then 5mph, or turning in parking lots at low speeds. I've replaced both LCA, upgraded Sway Bar with moog frame bushings and end links, new outer tie rods. Cv axle on drivers side as well. I'm also getting a creeking sound when turning both ways as well as the tire rubbing sound, there is no plastic rubbing in the inside of the tire. I'm not sure what either noise could be. Any ideas? 131k
    99 GTP, F1 Hood,CAI,HP TUNE,RoofRails,HID,Front/Rear STB,
  2. #2 Re: Tire rubbing sound.
    you got ss brake lines up front? maybe they are hitting the tires when you turn?
  3. #3 Re: Tire rubbing sound.
    Sep 2015
    Seattle
    Nope, stock brakes. Checked everything with the brakes. I'm stumped on this one. It sounds like plastic rubbing the tires, but it isn't lol
  4. #4 Re: Tire rubbing sound.
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Check your front brake splash guard/plate, it's down by the ball joint. Sometimes it gets bent in a little and gives you a noise.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  5. #5 Re: Tire rubbing sound.
    Sep 2015
    Seattle
    Yup, checked that alrdy. I'm wondering if it's my spring insulators.
  6. #6 Re: Tire rubbing sound.
    St. Louis
    Are you on stock struts still? I'd check the strut bearing/mount up top. Had that noise when mine were going bad. Upon uninstall I found out they had been replaced incorrectly (parts were in the wrong order). Once I installed new ones and got the correct setup in place no more noise.
  7. #7 Re: Tire rubbing sound.
    Nov 2012
    Madison
    My Monroe front mounts made the same noise and were installed correctly.
    I put in some Duralast from Autozone because I finally snapped on a Sunday and couldnt wait for an order
  8. #8 Re: Tire rubbing sound.
    Sep 2015
    Seattle
    I'm still on stocks, how do you tell if the top mounts are bad?
  9. #9 Re: Tire rubbing sound.
    St. Louis
    Not sure, at that mileage I'd be replacing all the struts/mounts anyway. Car will probably ride totally different.
    Here's a thread on it--> http://www.grandprixforums.net/threa...-keeps-failing
  1. 2008 strut rubbing rear tire
    By cumminstinkerer in forum Brakes/Suspension/Chassis
    Last Post: 02-08-2017, 06:11 PM
  2. Rubbing sound when turning hard nothing touching tire?
    By 04lss in forum General Grand Prix Discussion
    Last Post: 10-13-2015, 10:10 AM
  3. Tire or wheel make noise like its rubbing something
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 09-25-2014, 06:21 PM
  4. Popping/rubbing sound while turning right
    By CapnBreakAlot in forum General Tech Discussion
    Last Post: 04-30-2013, 01:52 PM
  5. Rubbing noise from front left tire
    By zeppelinrocks18 in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2009, 05:45 PM
