Thread: Massive inprovement in front end feel for 50$
Page 1 of 9 123 ... LastLast
Results 1 to 20 of 166
  1. #1 Massive inprovement in front end feel for 50$
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Had to rebuild the front end of the prix last week. Got forced off the road and took a 8 inch curb going 70mph. Sucks because the whole front end was replaced 3 months ago. Anyways while doing a bit of research I discovered the moog k200787 control arm bushing. In simple terms it eliminates the squishy rubber front control arm bushing with a ball and socket joint. Absolutely zero flex / play. I had them pressed into new acdelco arms and my goodness the difference is absolutely astounding. The front end is twitchy and responsive in ways I have never felt before.
    Rock auto has them for 22$ a pop and a shop shouldn't charge you much to press them in.
    Moogs page showing how they work
    Installed in arms
    Back in the car with new KYB struts (Bent to heck), Sway bar bushings (Factory mounts got demolished), And the control arms (Bont so bad the wheel was rubbing the rear of the wheel well)
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  2. #2 Re: Massive inprovement in front end feel for 50$
    Where are the carnage pictures?
  3. #3 Re: Massive inprovement in front end feel for 50$
    Pennsylvania, USA
    Nice find, this plus a poly bushing for the rear swivel point should be a pretty nice alternative to ZZP's insanely priced control arms. I think I've got some adapters at school that could allow me to press these in with a ball joint press.
    And hitting a curb at 70 mph? Jeez, I think you got away pretty good in terms of damage!
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  4. #4 Re: Massive inprovement in front end feel for 50$
    Dec 2008
    Lawndale, CA
    Nice. Did you replace the horizontal bushing as well?
  5. #5 Re: Massive inprovement in front end feel for 50$
    Enfield, CT
  6. #6 Re: Massive inprovement in front end feel for 50$
    GTP Level Member
    Aug 2012
    st louis park, MN
    Looks like you have a moderate leak in your engine compartment. Any idea what that is?
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  7. #7 Re: Massive inprovement in front end feel for 50$
    Apr 2011
    South Dakota
    Oil... Oil everywhere. Made a mistake and forgot to tighten rear cover while replacing the engine with a used one.... It goes ****ing everywhere.
    I love Decker<3
  8. #8 Re: Massive inprovement in front end feel for 50$
    Feb 2013
    Missouri
    Lol, I wonder where you got the idea?
    It's crazy the difference they make, it's hard to explain really. It's like the car seems to help you turn more. If you think about it, the stock style bushings are a chunk of rubber that's constantly fighting to be vertical. Since these are like a mono-ball, they just move freely without resistance.
  9. #9 Re: Massive inprovement in front end feel for 50$
    May 2008
    Schuyler, NE
    Good to hear. I need to get these in my car.
  10. #10 Re: Massive inprovement in front end feel for 50$
    Quote Originally Posted by Frosty View Post
    Nice rust prevention.
  11. #11 Re: Massive inprovement in front end feel for 50$
    Never Never Land
    Slightly off topic. I'm about to order LCA's and those bushings. Do you think the Delco's are worth the money over Dormans?
  12. #12 Re: Massive inprovement in front end feel for 50$
    Apr 2011
    South Dakota
    Absolutely. They are only 65$ each on amazon. 10x the quality.
    I love Decker<3
  13. #13 Re: Massive inprovement in front end feel for 50$
    Aug 2013
    McDonald PA
    Subbing
  14. #14 Re: Massive inprovement in front end feel for 50$
    Portland Oregon
    Well looks like I'm rebuilding my lca's. Any idea if zzp still sells the poly rear bushings? Wasn't able to find them on their site
  15. #15 Re: Massive inprovement in front end feel for 50$
    Apr 2011
    South Dakota
    Poly sucks for suspension components. 0-10 do not recommend. I have poly bushings in my zzp trailing arms and they make noise non stop. Never again.
    I love Decker<3
  16. #16 Re: Massive inprovement in front end feel for 50$
    Enfield, CT
    Quote Originally Posted by OH4CompG View Post
    I thought Moog made a poly rear bushing too?
  17. #17 Re: Massive inprovement in front end feel for 50$
    Antioch, IL
    rockauto has them, they are blue
    2009 Challenger SRT8
    Expert at being gay.
  18. #18 Re: Massive inprovement in front end feel for 50$
    Feb 2013
    Missouri
    I put mine in and I've had them on my Civic and everything, greased the **** out of them and they never made noise.
  19. #19 Re: Massive inprovement in front end feel for 50$
    Nov 2011
    NY
    Curious as to how these problem solver bushings have been working out? Any updates?
  20. #20 Re: Massive inprovement in front end feel for 50$
    Feb 2013
    Missouri
    Fantastic on my end, but its only been about 4 months. Still feels like new though.
  1. loud humming in front end and can feel vibration in my feet
    By brian19876 in forum General Tech Discussion
    Last Post: 07-09-2014, 11:12 PM
  2. massive flat spot into third WOT
    By redynscire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2011, 09:24 PM
  3. Massive Oil Leak
    By 2000superGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2011, 11:17 PM
  4. Massive water leak
    By hahaha38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2010, 07:19 PM
  5. WOAH! Massive Oil Leak!
    By CSteen85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2010, 12:30 AM
