Thread: 2001 GT needs brake overhaul and struts
Results 1 to 9 of 9
  1. #1 2001 GT needs brake overhaul and struts
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    My 2001 GT has been neglected for too long. At 92,000 miles its still on original struts/springs and all brake parts with the exception of pads. I know i have at least one caliper that the boot is torn (around the piston).
    I plan on keeping this vehicle for a long time so the plan is to replace all 4 calipers, rotors, struts/springs and new pads all the way around.
    Since i am replacing parts now would be a good time to upgrade, right?
    Looking for a good setup that doesn't require modifying any parts....just bolt back on.
    From what i am reading the 06+ impala calipers would work?
    Are guys doing front and rear with impala calipers?
    As far as struts go...NAPA or Monroe? Quick struts seem like the way to go
    I have the 16" Torque Star wheels.
    Thanks in advance for any and all suggestions!!
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  2. #2 Re: 2001 GT needs brake overhaul and struts
    get r1 e line rotors and scorched ceramic pads off ebay, they we be the best brakes you ever had. around 200 for all 4 corners shipped.
    being you want/need new calipers, this is the time to up grade to F bodys front calipers. will cost you no more really then stock replacements.
    you can get power stop caliper iirc, they come powder coated as well. they should have the rears as well.
    i just picked up a set of ebay struts for my regal, 221 shipped. ill have em installed next week i hope.
  3. #3 Re: 2001 GT needs brake overhaul and struts
    Toledo, Ohio
    Thanks Scotty, looks like I need to spend some time reading the Big Bad Brake thread too.
    Sent from my SM-N910V using Tapatalk
  4. #4 Re: 2001 GT needs brake overhaul and struts
    anything larger then f bodys needs larger wheels, so to keep it cheap, f bodys are the best bang for the buck for us. unless you also want to run larger wheels and tires. cha ching lol
  5. #5 Re: 2001 GT needs brake overhaul and struts
    Toledo, Ohio
    I really like my polished T-stars! So it'll be F-bodys or Impala calipers for the front. And maybe just oem for the rear....unless I can find some GXPs.
  6. #6 Re: 2001 GT needs brake overhaul and struts
    Toledo, Ohio
    My rear end sits an inch lower (27 1/2" from ground to top of wheel well) with an empty trunk and full tank of gas. I'd like to find "police/taxi" struts that fit but not if they'll raise the car much.
    Someone mentioned in another post that the 2003 impala police struts raised it about an inch, and that the newer police struts were designed to lift the car.
    Anyone with experience with older model police/taxi struts?
  7. #7 Re: 2001 GT needs brake overhaul and struts
    Nov 2012
    Madison
    You do get a few options to pick from. KYB and AC Delco seem to be the obvious choices from my perspective.
    I don't think quick strut should be associated with appearance. Quick struts are for lets turn this pig around and get it done results.
    The guys apparently on the Impala forums say the police quikstruts raise the car, then they raise the car.
    Bilsteins raise the car just like the results have said. Not by much but they do raise it.
    I would think KYB or AC delco would be a better bet for near OEM ride height.
    If you come to Madison I will let you have my old compg springs
  8. #8 Re: 2001 GT needs brake overhaul and struts
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Kyb makes an assembled unit.
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  9. #9 Re: 2001 GT needs brake overhaul and struts
    Toledo, Ohio
    Thanks guys!! Yeah, even getting the OEM AC Delcos would be an improvement in both ride and ride height over the 16 yr old struts and springs on it now.
  1. Brake Booster on 2001 GP 3.8 GT
    By scha0786 in forum General Tech Discussion
    Last Post: 05-16-2016, 07:49 AM
  2. hellp with GP GXP struts springs wheels on a 2001 Regal
    By REGAL GUY in forum Brakes/Suspension/Chassis
    Last Post: 10-13-2015, 06:06 PM
  3. 2001 GTP - Replacing Struts - KYB GR2 plus other parts?
    By zguy in forum Brakes/Suspension/Chassis
    Last Post: 03-19-2012, 10:14 PM
  4. 2001 GTP - Abnormal tire wear (cupping) due to struts?
    By zguy in forum General Tech Discussion
    Last Post: 01-09-2012, 10:35 PM
  5. 2001 GTP Brake Booster
    By Greg66 in forum Introductions/Noob Questions
    Last Post: 10-28-2009, 08:37 AM
