Thread: Who's replaced a rack and pinion?
Results 1 to 20 of 21
  1. #1 Who's replaced a rack and pinion?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys my rack and pinion along with the power steering pump is shot. I also want to swap all the lines as well. How difficult of a job is this for a moderate backyard mechanic to do. The cheapest quote I got from a shop was 400$ labor only. Usually I do all the work on my car but all the power steering stuff seems to have no clearance for much of anything and looks like a real pita
    Sent from my LG-H901 using Tapatalk
  2. #2 Re: Who's replaced a rack and pinion?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    I've done it twice on my car it's not to bad looks worse then it is definitely not fun though. Take the sway bar completely out and you can slide it out the passenger side a lot of guys drop the subframe just seems ridiculous why if you don't have to.
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  3. #3 Re: Who's replaced a rack and pinion?
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    I also just changed my rack last weekend. after you take off the subframe it goes pretty smooth. but i also had my trans out too.
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  4. #4 Re: Who's replaced a rack and pinion?
    Oct 2015
    How long did it take yoy
  5. #5 Re: Who's replaced a rack and pinion?
    Jul 2015
    Jamestown, NY
    The first time a little longer then the second time idk a couple hours or so I don't exactly hurry or anything I take my time lol
  6. #6 Re: Who's replaced a rack and pinion?
    Apr 2014
    Chicopee,MA
    Longer than youd like. Start early.
  7. #7 Re: Who's replaced a rack and pinion?
    Oct 2015
    Is there any how tos on it because I have absolutely no clue what I'd be doing lol. Also can anyone verify if a 99 gt came with the magnasteer option. There is a wire that goes into the rack which makes me believe it's the magnasteer
  8. #8 Re: Who's replaced a rack and pinion?
    St. Louis
    If you have a wire that is coming from the rack and connects to something then you have Magnasteer. Think the code on the trunk sticker was NV7 or NV9 or something along those lines.
  9. #9 Re: Who's replaced a rack and pinion?
    St. Louis
    here's a thread from the how-to section--> http://www.grandprixforums.net/threa...highlight=rack
  10. #10 Re: Who's replaced a rack and pinion?
    SWPA
    Quote Originally Posted by Tonkin2000GT View Post
    Its two bolts to drop the subframe. It takes more work and more effort to do it your way. With the subframe dropped you have a ridiculous amount of room.
  11. #11 Re: Who's replaced a rack and pinion?
    if you got a wire its magna steer. youtube has vids, they use a lift but you can see how it comes out.
  12. #12 Re: Who's replaced a rack and pinion?
    Oct 2015
    I do have the wire although I checked the trunk and do not have any of those rpo codes.
    Thank you for the how to!!!
  13. #13 Re: Who's replaced a rack and pinion?
    wire leads up to the tranny shiftier, has a blue plug.
  14. #14 Re: Who's replaced a rack and pinion?
    Oct 2015
    That would be what I have
  15. #15 Re: Who's replaced a rack and pinion?
    Jul 2015
    Jamestown, NY
    Yea but it's really not that big of a deal to fish it out and I've never had those bolts out nor do I have a big compressor and impact.
  16. #16 Re: Who's replaced a rack and pinion?
    dont need air, they come right out most of the time. and it really does make the whole job easier, from getting the lines off to the bolts out, to extraction of the rack.
  17. #17 Re: Who's replaced a rack and pinion?
    Oct 2015
    https://www.amazon.com/gp/aw/d/B00TL..._1486274080081
    This seems like a good deal with the debate right?
  18. #18 Re: Who's replaced a rack and pinion?
    Oct 2015
    That video is amazing! Although still seems like quite a b*tch to do without a lift
  19. #19 Re: Who's replaced a rack and pinion?
    SWPA
    I did it lying on my back with nothing but a jack and stands. The only issue I ran into was my line wrench was a hair too long and was hitting the cat on my ZZP downpipe. After fighting with the angle for a few minutes I got pissed enough to cut 2 inches off the wrench. After that I got the lines right off.
    Without the subframe being dropped I don't see any easy way to access the lines. Doing it without dropping the subframe just sounds like a terrible idea. Oh, and when I did the rack on my car I think I was around 170k miles and the bolts came right out without hassle.
  20. #20 Re: Who's replaced a rack and pinion?
    Oct 2015
    Is the rack a common failure on our grand prixs
  1. rack and pinion
    By asite57 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2011, 09:53 PM
  2. rack and pinion
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 02-21-2011, 09:53 AM
  3. GTP rack and pinion
    By mikedinthecity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2010, 12:33 AM
