Thread: Replacement subframe bushings 00 GT
Results 1 to 7 of 7
  1. #1 Replacement subframe bushings 00 GT
    St. Louis
    Well, now that I have all new suspension, I need to get on replacing all the subframe mounts. I've read some threads and have some differing opinions. Here's some of the one's I've seen mentioned so hoping someone can confirm which would be better, or if there is something else out there that'll work best. I know there has been some discussion on the re-use of the subframe bolts, so I'd like to know if I should bother to replace those too. At this mileage it may be worth it just for piece of mind.
    04+ impala fe4 police package are firmest they should have a green line around them
    05 comp g. Stiffer and cheaper bushings
  2. #2 Re: Replacement subframe bushings 00 GT
    GT Level Member 0069GTP's Avatar
    Oct 2014
    Western NC
    Subb'd. Curious as well. I would replace the steering rack bushings as well while your at it, if you haven't already.
  3. #3 Re: Replacement subframe bushings 00 GT
    Quincy, Mass
    Do you have part numbers for those? Rockauto only shows dorman ones and they are the same ones for both those vehicle.
    No more GP 04 Impala SS Indy:
  4. #4 Re: Replacement subframe bushings 00 GT
    St. Louis
    I'll see if I can dig up part numbers.
    New rack w/ bushings went in about 100K ago. Guess it couldn't hurt to re-check em.
  5. #5 Re: Replacement subframe bushings 00 GT
    Quincy, Mass
    Quote Originally Posted by FordMan77 View Post
    They are only $8
  6. #6 Re: Replacement subframe bushings 00 GT
    St. Louis
    True. Might as well do those to so that literally EVERY damn part up front is new again.
    I've found some part numbers and am researching, but have what may be a stupid question... Since the above mentioned bushings are for the aluminum based subframes, did they change at all on those cars or do they still fit the steel subframes of 97-03? I've honestly never looked at the alum. version.
  7. #7 Re: Replacement subframe bushings 00 GT
    Oct 2014
    Western NC
    It would be nice if there were a poly option out there, but I haven't found any. I also wonder if a solid mount option would be too harsh or not, I would think that someone has surely tried it.
  1. Subframe Bushings
    By Dee23 in forum Brakes/Suspension/Chassis
    Last Post: 04-19-2016, 01:24 PM
  2. subframe bushings
    By SgtMarshal in forum Brakes/Suspension/Chassis
    Last Post: 02-05-2016, 04:13 PM
  3. subframe bushings
    By 310toumad in forum Brakes/Suspension/Chassis
    Last Post: 11-21-2015, 01:35 PM
  4. Subframe Bushings
    By ls1camino in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2012, 08:14 AM
  5. subframe bushings??
    By nicks98gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2011, 09:54 PM
