Thread: Ft brake pads
Results 1 to 13 of 13
  1. #1 Ft brake pads
    SE Level Member Royalblue's Avatar
    Waldorf, MD
    Do you need to open bleeder valve on 2001 gtp to change ft brake pads it has abs brakes
  2. #2 Re: Ft brake pads
    Apr 2015
    Muskegon, Mi
    I always do just to keep the nasty fluid from being pushed back into the system. Makes compressing the caliper pistons much easier too.
  3. #3 Re: Ft brake pads
    no you dont. open the cap on the master so it can be pushed back up with out any back air pressure, if its getting close to over flowing you can mop some up with a clean rag to drain it.
  4. #4 Re: Ft brake pads
    Quote Originally Posted by Troutman53 View Post
    Guess what, all the fluid that is in the piston/caliper is the same nasty fluid that is in all the lines and all of the master/res.
  5. #5 Re: Ft brake pads
    Waldorf, MD
    Thanks you all
  6. #6 Re: Ft brake pads
    Apr 2016
    Maryland
    Do not open the master cylinder!!! fluid will go everywhere unless you are really low on fluid to begin with. If the piston in the caliper is really hard to push in you might have a bigger problem.
  7. #7 Re: Ft brake pads
    this is so false. only way its coming out is if it over flows. lets the piston push in a bit easier. for the record, i bleed brakes cap off, swap pads cap off. cap always off. never in my life has fluid shot out of it, this goes for like 30 years of brake jobs., old and new cars.
    Quote Originally Posted by Dacton1985 View Post
  8. #8 Re: Ft brake pads
    Apr 2016
    Maryland
    I had it happen to me once and I will never take that chance again! Lol
  9. #9 Re: Ft brake pads
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    You can also suck some fluid out of the top of the res with any kind of plastic bottle that has a somewhat pointy spout. I've used $ store squeeze bottles that I think are meant for ketchup & mustard, or oil or somethink.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  10. #10 Re: Ft brake pads
    Apr 2016
    Maryland
    Good thinking cheatah
  11. #11 Re: Ft brake pads
    GT Level Member willie14's Avatar
    Jun 2016
    westland mi
    Yea I'm with scotty on this one.... While changing rotors pads etc on my 98 GP, I left cap on while fluid was full and blew out the opposing brake line while compressing brake piston....made a huge mess and turned 1 simple problem into a whole new one...at least I got to change out the rear brake lines but i just bought car n wasn't too happy bout it....cap off as a precaution...��
    98 Grand prix SE to GTP conversion( in works). Full body conversion in works, drilled n slotted rotors, ceramics, all new suspension, custom CAI, NGK wires/Vpower plugs, SD headers, 180 Tstat, AND A WHOLE BUNCH OF PAINT BABY!! Tuned by E&J performance.
  12. #12 Re: Ft brake pads
    Jul 2010
    Coquitlam,BC,Canada
    Don't push so hard or so fast.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #13 Re: Ft brake pads
    Nov 2015
    WI
    I have just opened the cap on the master on all the brakes i have ever done. should not have an over flow issue unless you were adding fluid as your pads wore. Go slow and you should be fine.
  1. 04+ brake pads
    By Mirraco in forum General Grand Prix Discussion
    Last Post: 09-21-2014, 07:21 PM
