Hey guys,
I have a 2001 GP SE. My ABS light has come on every time I drive the car. I found the problem. It's the sensor on the right front wheel bearing. The wire broke off at the sensor. There isn't enough wire to solder a new piece of wire because it broke off to close to the sensor. I live in FL. now so I never use the ABS. Only time I did was in the snow up in MN. I wanted to pull the fuse but the ABS fuse is a combo A/C clutch and ABS ignition fuse. How can I disable the ABS so that the light goes out? P.S I had the bearing replaced about 2.5 years ago w/ an AC Delco bearing so I'd rather not replace it again.
