Thread: Caliper slide pin not sliding.
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Caliper slide pin not sliding.
    GT Level Member Jaredthefail's Avatar
    Nov 2015
    Olive branch, MS
    Quote Originally Posted by Bronco Boy View Post
    Yup, the dust boot is press fit. Gently pull and or twist. If you have new one's, pull the hell out of the old one's. LOL
    And the boot only needs to be removed if being replaced. It can stay put for the caliper bolt.
    Yeah mine is staying because I don't have replacement ones. Lol
  2. #22 Re: Caliper slide pin not sliding.
    Quote Originally Posted by Jaredthefail View Post
    if the ones you have are not torn up you can just clean them and push em back on. its literally just a boot that slides on, (no tricks) the pin just fits through it.
  3. #23 Re: Caliper slide pin not sliding.
    Nov 2015
    Olive branch, MS
    Thanks for all the help. I can now drive my car without worrying about the pads wearing down weird.
  4. #24 Re: Caliper slide pin not sliding.
    canal winchester, ohio
    So....the lower caliper bolt is getting stripped out. I went.to the auto parts places and all they have are the ones shown in the previous post (no rubber without buying another kit). My top bolt had no rubber at the end, my lower does. I go to the local junkyard this morning and the first caliper bolt I pull from the bottom does not have the rubber...the top did. Ummm, I check 3 other cars...all different (1 with rubber bolt on top, 2 with rubber on bottom.
    Wtf? The gm parts diagram doesn't help for crap either. Must not matter.
  5. #25 Re: Caliper slide pin not sliding.
    Jul 2010
    Coquitlam,BC,Canada
    Pretty sure only one pin per caliper (on my car) have the end rubber piece. I think that piece just acts like a guide, so having it on all 4 shouldn't be a bad thing.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #26 Re: Caliper slide pin not sliding.
    im sure you'll be ok with out that rubber tip on the pin.
  1. Bent caliper bracket slide pin recommendations
    By Mr D in forum Brakes/Suspension/Chassis
    Last Post: 06-21-2014, 01:43 PM
  2. Brake caliper slide pin?
    By Fahrenheit in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2012, 12:21 PM
  3. Belt sliding off
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2011, 07:16 PM
  4. sick of sliding around....
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-23-2009, 01:39 PM
  5. Slide Pin Bushings
    By GP Modder in forum Brakes/Suspension/Chassis
    Last Post: 12-08-2008, 02:10 AM
