Thread: Caliper slide pin not sliding.
Results 1 to 20 of 26
  1. #1 Caliper slide pin not sliding.
    GT Level Member Jaredthefail's Avatar
    Nov 2015
    Olive branch, MS
    My brakes work okay but I wanted to check the pad wear and I found that the front pads are wearing a little uneven. I read that the slide pins could be the problem. When o took out the pins the top came out just fine, but the bottom one was stuck in there. So I beat it out and greased it and then a few days later I tried to take it out again and it was hard to get out again.
    What could be causing this and how do you fix it?
  2. #2 Re: Caliper slide pin not sliding.
    Clean it out, you can use like a small drill bit in the hole to remove crud and rust or whatever. Don't drill the hole any bigger just clean it out.
    Then grease everything back up and see what it's like then.
  3. #3 Re: Caliper slide pin not sliding.
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Are there plastic sleeves on the pin? Mine came off in the holes. Lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  4. #4 Re: Caliper slide pin not sliding.
    good old rust. you might need to use vice grips and a hammer hitting the vice grips to pull the pin out, brake cleaner and a little screw driver work to free up dead grease in the hole. then grease the hell out of it and work the pin in and out till its smooth.
  5. #5 Re: Caliper slide pin not sliding.
    Nov 2015
    Olive branch, MS
    Yeah the first time I got it out the plastic piece came with it... is that supposed to be moving too?
  6. #6 Re: Caliper slide pin not sliding.
    Jul 2010
    Coquitlam,BC,Canada
    As mentioned, remove the pin and clean it. Then clean inside where the pin goes (I used a piece of red scotchbrite). Lube it all up (I use Syl-Glyde) and put it back together. The plastic pieces can come off; just put em back on if they aren't damaged.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Caliper slide pin not sliding.
    Nov 2015
    Olive branch, MS
    Yeah tomorrow I'll take it apart again. Brake cleaner is a great idea and I also didn't use the right kind of grease...
  8. #8 Re: Caliper slide pin not sliding.
    Nov 2015
    Olive branch, MS
    Quote Originally Posted by WarStryker13 View Post
    what exactly came off on the sleeve? do I need to replace that??
    Sent from my App Runtime for Chrome using Tapatalk
  9. #9 Re: Caliper slide pin not sliding.
    Oct 2014
    Frederick, MD
    No, I just had a case of terrible PO.
    I got all new calipers, the ones it had were mismatched, cross threaded, and leaking... if your plastic pieces look undamaged, keep them.
  10. #10 Re: Caliper slide pin not sliding.
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Jaredthefail View Post
    One caliper bolt (on each side) has a plastic guide on the end. It is needed, so if missing, it must be replaced.
    The two small things, lower left and lower right.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Caliper slide pin not sliding.
    Nov 2015
    Olive branch, MS
    Yes I still have that on it and as far as I know they are still in good condition. (no cracks or breaks) thanks for clarifying that
    I also forgot to mention it makes a weird noise when you press the brakes. We'll see if it goes away after cleaning it out for real tomorrow
  12. #12 Re: Caliper slide pin not sliding.
    Jul 2010
    Coquitlam,BC,Canada
    It should. When the pad can't move freely it can make all kinds of neat noises.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #13 Re: Caliper slide pin not sliding.
    canal winchester, ohio
    whats interesting is that I bought a replacement caliper bolt for mine and it didnt have the little piece on the end. I tried AutoZone and i didnt buy the caliper bolt because it didnt match. I went to Advance and they had the same incorrect looking bolt so I said "maybe it is a new design". Also, the end is different (skinnier on the end). I post some pictures whenever start working on it again.
  14. #14 Re: Caliper slide pin not sliding.
    my stock pins look like the set on the left there. rubber tip on one.
  15. #15 Re: Caliper slide pin not sliding.
    The left is the stock. The right is the replacement. I haven't installed it yet
  16. #16 Re: Caliper slide pin not sliding.
    Oct 2014
    Frederick, MD
    Don't install it...
    if it doesn't match, or give a reason why it's different, it's not the right part.
  17. #17 Re: Caliper slide pin not sliding.
    Jul 2010
    Coquitlam,BC,Canada
    The caliper bolt is sold on its own. To get the plastic guide thingy you need to get a caliper hardware kit, which also has the rubber booties that go onto the caliper.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  18. #18 Re: Caliper slide pin not sliding.
    Nov 2015
    Olive branch, MS
    How do you get the rubber boot off without breaking it? I'm about to spray brake parts cleaner in there
  19. #19 Re: Caliper slide pin not sliding.
    the one on the end of the caliper? its a dust boot really, you just pull it off, theres a lip it seats in.
  20. #20 Re: Caliper slide pin not sliding.
    Jul 2010
    Coquitlam,BC,Canada
    Yup, the dust boot is press fit. Gently pull and or twist. If you have new one's, pull the hell out of the old one's. LOL
    And the boot only needs to be removed if being replaced. It can stay put for the caliper bolt.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Bent caliper bracket slide pin recommendations
    By Mr D in forum Brakes/Suspension/Chassis
    Last Post: 06-21-2014, 01:43 PM
  2. Brake caliper slide pin?
    By Fahrenheit in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2012, 12:21 PM
  3. Belt sliding off
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2011, 07:16 PM
  4. sick of sliding around....
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-23-2009, 01:39 PM
  5. Slide Pin Bushings
    By GP Modder in forum Brakes/Suspension/Chassis
    Last Post: 12-08-2008, 02:10 AM
