Thread: ABS kicking on way too quick
Results 1 to 10 of 10
  1. #1 ABS kicking on way too quick
    SE Level Member sn95gt50's Avatar
    Jul 2008
    A few years ago, my ABS started pulsing when coming to a stop occasionally. It would pulse a little and kinda like losing breaking for just a few seconds, if that. At one point it threw a code when it happened, I think it was ABS but could have been check engine. I pulled into a Chevy dealer and they put their scanner on it and they said it could connect. Recently, it started doing it again, no check engine light. Tonight I put my code scanner on it just to see, figured it wouldn't work since the dealer one didn't. Plugged it in, it connected and everything was fine, worked properly but didn't give me any indication of a problem.
    So, what do I do? Judging by the symptoms, I am going to guess that one of my ABS sensors are bad. Is there anyway to test them? Any suggestions on how to proceed?
    Any help would really be appreciated.
    Thanks,
    John
  2. #2 Re: ABS kicking on way too quick
    if the abs light is on you need a abs scanner to read those. best to get it scanned or you can be tossing money at it guessing.
    typical your issue is a bad ebcm, or bad hub. scanning will lead to a clear path to the issue tho.
  3. #3 Re: ABS kicking on way too quick
    Jul 2008
    Not getting an ABS light now, that is what makes it nearly impossible to diagnose. Guess I will run it into the dealership and let them take a whack at it. If I am not getting an ABS light will the an ABS scan say anything?
    Any other suggestions?
    Thanks for the quick reply.
    John
  4. #4 Re: ABS kicking on way too quick
    when scanned it will show history of codes that have been set in the past. most shops will clear all codes and see what code comes back first.
  5. #5 Re: ABS kicking on way too quick
    Jul 2008
    Can the ABS be disabled by pulling the ABS fuse until I can get it fixed? I assume that doing that will make the brakes act as traditional brakes.
  6. #6 Re: ABS kicking on way too quick
    sure can. i got the fuse pulled my self, it will set the abs light tho, maybe the brake light too.
  7. #7 Re: ABS kicking on way too quick
    Jul 2010
    Coquitlam,BC,Canada
    When you pull the ABS fuse, you also loose the A/C clutch.
    If you unplug one of the ABS sensors, you just loose ABS.
    In both scenarios, the ABS and TRAC lights will be on all the time.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: ABS kicking on way too quick
    my abs fuse in the in car fuse box has been removed for over a year, ac still works fine.
  9. #9 Re: ABS kicking on way too quick
    Jul 2010
    Coquitlam,BC,Canada
    Because your Regal fuse is in a different spot than the GP fuse. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  10. #10 Re: ABS kicking on way too quick
    used my ac for the first time this year today,,,still ice frigging cold lol only thinn im yet to fix it seems.....
  1. P0069 kicking my xxx!
    By J57ltr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2021, 01:41 PM
  2. Still alive and kicking
    By Anthony Smith in forum Off Topic Discussion
    Last Post: 02-03-2015, 08:40 PM
  3. Kicking some stuff around
    By NR92 in forum General Grand Prix Discussion
    Last Post: 10-21-2012, 10:34 PM
  4. ABS kicking in when it shouldn't be...
    By mikeplan14 in forum Brakes/Suspension/Chassis
    Last Post: 05-31-2011, 08:10 PM
  5. Kicking myself in the ass right now
    By KwazrollinZ28GTP in forum The Rant Forum
    Last Post: 03-29-2011, 08:52 PM
