Thread: Suspension/Handling Upgrades
Results 1 to 13 of 13
  1. #1 Suspension/Handling Upgrades
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    So, I need new LCAs and probably other things on my GTP (clunks really bad stop/go). I wanted to just re-do everything necessary to get better handling, and the person I bought it from seemed like a very gas/oil/tires and go person - so I'm betting there has been minimal suspension maintenance the three years they owned it.
    Anyhow, right now I just have a 33mm Dorman sway bar with new Moog poly bushings and new brackets and bolts and a rear GMPP swaybar.
    So, I've been doing some reading around and I'm looking at front and rear endlinks, rear bushings, solid trailing arms, LCAs, moog k200787 problem solver control arm bushing.
    Curious on recommendations on the parts I still need, and if I should get anything else.
    Any difference between:
    Boxed trailing arms the W-Body Store sells and the tubular ones ZZP sells
    LCAs: between Moog, Dorman, W-Body store
    Endlinks/rear bushings: ES and Moog
    Was also looking at doing engine mounts (maybe transmission too, not sure if that's necessary?) in the future. Curious if the price for Intense's http://intense-racing.com/PROD/3800-PRO-UMMP-xxx.html is worth it over like WBS's http://www.wbodystore.com/suspension...ne-mounts.html. Then http://www.wbodystore.com/suspension...ine-mount.html good?
    Also, brakes, are LaCrosse Super front and rear brakes identical to GXPs? And I would assume I'll need F-body banjo bolts for front and rear, and that will be all I need in addition to the brakes? Also, for rotors, do I have to go OEM, or are there any other cheaper options that are good for the GXP brakes? Not really wanting to spend $250 on rotors, or if I just do the front $120....
    Open to suggestions, what parts/brands you recommend, and really any info you have.
    Thanks!
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  2. #2 Re: Suspension/Handling Upgrades
    Dorman trailing arms are solid bars, cheaper and better than the factory stamped steel ones. I wouldn't shell out extra money for name brand or zzp/w-body store units.
    The front brakes for sure on the Buick Allure/lacrosse super are the same size as the GXP but just with no vents/drilled holes. The rears I never looked into.
  3. #3 Re: Suspension/Handling Upgrades
    Jun 2015
    Okay, so two of these: http://www.rockauto.com/en/moreinfo....432257&jsn=460
    So, there shouldn't be any difference for DD'n between GXPs and Supers.
  4. #4 Re: Suspension/Handling Upgrades
    GTP Level Member PaintChips97's Avatar
    Apr 2015
    Illinois
    I went with the BMR tubular trailing arms, they were only $87 shipped from LMPerformance. The grease zerks and poly bushings are the biggest upside of them, plus they're way bigger than the Dorman bars (not that it matters much, the Dorman ones are plenty strong). Just something to consider
    04 Comp G - a few mods, lots of OEM+ goodness, shiny stuff
  5. #5 Re: Suspension/Handling Upgrades
    If your on stockers and go BMR might wanna make sure you have enough clearance between the TA and tire
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  6. #6 Re: Suspension/Handling Upgrades
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    If you have a local junkyard, police Impala trailing arms are the same as GMPP, if you want a cheaper option. Just make sure the rubber bushings are still in good shape.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  7. #7 Re: Suspension/Handling Upgrades
    Apr 2015
    Illinois
    Quote Originally Posted by REDCRAPGP View Post
    I'm running mine on stock-sized rims and 245 tires with no clearance issues, and you can use washers as spacers to get more clearance if needed
  8. #8 Re: Suspension/Handling Upgrades
    Jun 2015
    Quote Originally Posted by Impala131 View Post
    Can I get replacement bushings? Local yard might have a 9th gen Police Impala... Thanks for the info.
    Sent from my LG G4 using Tapatalk.
  9. #9 Re: Suspension/Handling Upgrades
    Enfield, CT
    Yes replacement bushings are on rock auto. Better off asking booba what size poly bushings he used.
  10. #10 Re: Suspension/Handling Upgrades
    Enfield, CT
  11. #11 Re: Suspension/Handling Upgrades
    Knoxville, TN
    What I found really interesting, was the junkyard GMPP trailing arms were 1/4 - 1/2" shorter than my stock trailing arms (bolt hole center to bolt hole center). I'm curious if the stock U-bend arms really stretched that much.
  12. #12 Re: Suspension/Handling Upgrades
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Not sure what would stretch them, there is no drive torque applied to the rear wheels.
  13. #13 Re: Suspension/Handling Upgrades
    Banned
    Change the subframe bushings if you want that clunk to go away
  1. suspension upgrades for 04+ GPs
    By gxp revenge in forum Brakes/Suspension/Chassis
    Last Post: 06-03-2014, 09:05 PM
  2. better handling suspension
    By Matt Palm in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2012, 09:40 PM
  3. Replies: 1
    Last Post: 05-06-2011, 07:36 AM
  4. Need Suspension upgrades
    By Luda in forum Brakes/Suspension/Chassis
    Last Post: 04-15-2010, 09:17 PM
