Thread: lca question. plz help...
Results 1 to 3 of 3
  1. #1 lca question. plz help...
    SE Level Member 08 gp lvr's Avatar
    Nov 2011
    north bay, ontario
    I replaced my lca as well as the left axle shaft. Needless to say that was a pita to remove it from the tranny. Anyway, when i removed my lca i compared it to the new one and everything was the same except for the welded bracket were the stabilizer links go thru the lca. On the new one theywere located about 3 1/2cms or 1 1/2" closer towards the tranny side. So i put everything back totogether and replaced the links w new ones and it cracks almost everytime i hit a good bump or turn the wheel. It says on the box its for a 24mm sway bar and i hv a 33mm. Weird thing is they dont hv a listing for a 24mm bar for that year. Any help would be appreciated. 2008 gp base
  2. #2 Re: lca question. plz help...
    Nov 2011
    north bay, ontario
    I meant to say the bracket on the control arm for the link is off by a good 1" farther out towards the inside of the motor. That would make the sway needing to be longer. Thanks again
  3. #3 Re: lca question. plz help...
    GXP Level Member
    Mar 2015
    Tomball
    Post a picture.
    Jeff
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
