Thread: 2012 Ford Taurus Police Brakes
Results 1 to 9 of 9
  1. #1 2012 Ford Taurus Police Brakes
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    So, I was at the JY yesterday and spotted a 2012 Taurus Police model, wheels were gone but all the brakes were intact. Pretty big brakes, appears to be 13" both front and rear. Dual piston front, single piston rear. Appear aluminum. Any use to us W-Body guys? Seems that the 13" rear would be a unique upgrade if adapted properly. Not particularly useful, but might be cool if you want 13" all around.
    2012 Ford Taurus Police Brakes Attached Images
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: 2012 Ford Taurus Police Brakes
    hangover park IL
    That front pbr setup should be identical to the gxp pbr brakes
    ~James~ Psychotic Gearhead
  3. #3 Re: 2012 Ford Taurus Police Brakes
    Through a small search it looks like the center bores are too different to make work. 64mm for the ford and 70mm for a grand prix.
  4. #4 Re: 2012 Ford Taurus Police Brakes
    Arizona
    I would just like to be able to get off of having single piston rears
  5. #5 Re: 2012 Ford Taurus Police Brakes
    hangover park IL
    youd make yourself happier with an adjustable proportioning valve and your current brakes.
    the TR has stock rears and they work at least twice as hard meow. turn it up enough and you can get em to lockup even.... thats a pretty well sized caliper and rotor for the weight at that end of the car.
  6. #6 Re: 2012 Ford Taurus Police Brakes
    hangover park IL
    lines converted to F/R split system with all new copper nickel lines as opposed to OEM diagonal split. lines run up through floor to adjustable proportioning valve under front of drivers seat for on the fly adjustments.
    HUGE improvement over the stock junk that will never give you enough pressure/stopping power without increasing piston surface area.
  7. #7 Re: 2012 Ford Taurus Police Brakes
    hangover park IL
    Quote Originally Posted by Impala131 View Post
    the question would be if the hat offset was the same or nearly so...then you could use the taurus calipers/brackets with the GM rotors
    i wonder what the piston dia is....
  8. #8 Re: 2012 Ford Taurus Police Brakes
    Donating Users timboku's Avatar
    Montgomery, IL
    I have these same brakes on my explorer sport. I will have to take a closer look and see how they compare to the gxp brakes.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  9. #9 Re: 2012 Ford Taurus Police Brakes
    opening up the hub bore on the rotors is a 20 minute job for a machinist.
  1. moms ford Taurus coolant leak help.
    By Scottydoggs in forum General Tech Discussion
    Last Post: 01-01-2014, 03:39 AM
  2. Replies: 2
    Last Post: 10-17-2013, 07:07 PM
