Thread: shorter AGX front struts for GP? any swaps?
Results 1 to 13 of 13
  1. #1 shorter AGX front struts for GP? any swaps?
    SE Level Member CadVetteStang's Avatar
    Jun 2014
    Little Rock, Arkansans
    Looking for shorter front struts that will bolt up to to the 97-03 GP. Car will be lowered about 1.5". Needs to be a car that KYB makes the AXG for.
    I talked with one of their tech reps on the phone and he didn't have the ability to look up a shorter strut with the same mounting styles.
    If I am unable to find a shorter strut, can I get some feedback about how well the AGX works with 1.5"-2" drop, bottoming out, and spring rates that work well?
    I'm swapping in a jk spring and will cut to length to obtain desired drop.
    LCA to frame mounts will be modded to retain geometry.
    Thanks,
    Cody
  2. #2 Re: shorter AGX front struts for GP? any swaps?
    SWPA
    Cutting springs is about the dumbest thing you could think of doing.
  3. #3 Re: shorter AGX front struts for GP? any swaps?
    Agreed
    04 Comp G.
  4. #4 Re: shorter AGX front struts for GP? any swaps?
    Jun 2014
    Nothing wrong with cutting the TG end of a coil if done correctly with a saw. These springs have a current var. rate av. of 416 lbs. / inch. After cutting one coil they should be in the 530 lb. range.
    The LSA IRS in my Edorado had stock springs rated at linear 279 lbs./ inch. For my swap, I used linear springs rated at 760 lbs./inch. After cutting they are rated 1000 lbs./inch. I have logged 35,000 trouble free miles on them.
    Sure, its dumb for the uninformed to attempt something of that skill level, but it's something suspension builders and racers do. Kind of like this- a plumber should not perform heart surgery, because it's a doctor's thing.
    But it's not dumb for doctors to do.
    Now, I hope the light-weights have all weighed in... I'm ready for some tech from those who are in the know...... maybe, I should have screened the novices out first.
  5. #5 Re: shorter AGX front struts for GP? any swaps?
    Aug 2013
    McDonald PA
    wut.... this is kinda like mind blowing buy or make coilovers done. call it a day
  6. #6 Re: shorter AGX front struts for GP? any swaps?
    Jun 2014
    I was going to do coilovers, but my 18X8.5 winter wheels and 255/45 tires are very close to the strut and my 18X10 summer & racing wheels would rub the coils if it had coilovers. I'm going to keep the 275/40's under the fenders. Can't do that without the 7.2" backspacing.
    Autocross racer & suspension builder.
    Bulder & former owner: "Shelter" movie Mustangs.
    Wife's: 2004 Grand Prix GT (DD)
    Mine: 2002 Eldorado Sport Coupe (autocross & DD)
  7. #7 Re: shorter AGX front struts for GP? any swaps?
    I honestly don't think there is another strut that would just bolt into our stock location.
    I think some sort of bracket would have to be made, then raised up from the sounds of it. With such wide wheels, the bottom of the strut would have to be up so darn high to not rub the tire.
  8. #8 Re: shorter AGX front struts for GP? any swaps?
    Jun 2014
    I've already done the measuring and fitting. The GP strut is a direct fit on my Eldorado. I just have to have the sway bar tabs welded on ( another reason I can' t use coilovers. I have a lot more fender clearance than the WBodys have.
  9. #9 Re: shorter AGX front struts for GP? any swaps?
    Your first post fails to mention that you are trying to bolt these parts to a cadillac. That is a helpful thing to know.
  10. #10 Re: shorter AGX front struts for GP? any swaps?
    Jun 2014
    Well, I'm in a GP forum talking about GP struts to GP owners who have used them in GPs.
  11. #11 Re: shorter AGX front struts for GP? any swaps?
    hangover park IL
    you can make strut mounted sway bar links work perfectly fine with coilovers with just an angle iron bracket at the knuckle bolts
    ~James~ Psychotic Gearhead
  12. #12 Re: shorter AGX front struts for GP? any swaps?
    hangover park IL
    the only one I know of that might be shorter is the Grand Am struts from the Grand Am with a5 by 115 lug pattern. unfortunately I don't know if there anything more than a tiny bit shorter. And I'm not altogether sure you can get AGX's for em.
    you coil over clearance issue you are mentioning is also what screwing us over on our 11 inch wide slicks. so I am laying back the struts with custom strut mounts.
  13. #13 Re: shorter AGX front struts for GP? any swaps?
    Jun 2014
    Originally, I wanted a bolt-on sway bar link bracket attached to the bottom of the spring perch to avoid the need to have a shop weld one one on each time I change struts. However, worried about flex.... I was going to build knuckle bolt brackets anyway to secure the speed sensor in the Cadillac's factory location, which is just above the knuckle bolts .... Thinking about it, now, I guess I could fab a bracket that attached in both locations running the length of the strut body to attach both the sway bar link and the speed sensor wire.
    That would be a one time fabrication and would only require the drilling of one or two holes in the perch - eliminating the need for a shop and the risk of overheating the strut..... AND I could have more than one hole for the end link for adjustability AND could set the ride height BEFORE drilling the primary end link hole so the bar could be set with level arms......
    Wow! Thanks for that suggestion. I'll start designing a test bracket.
    (I drive this car 25,000 miles per year, so the ability to change struts without having to have a welder would be awesome!)
  1. Front Struts
    By Speedy1973 in forum Wanted To Buy - Parts
    Last Post: 04-06-2014, 11:33 AM
  2. 05 Front Struts
    By jkazam1 in forum Brakes/Suspension/Chassis
    Last Post: 03-29-2013, 03:28 PM
  3. My quest on finding shorter struts
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2012, 12:41 AM
  4. Front Struts
    By GPSims39 in forum Brakes/Suspension/Chassis
    Last Post: 05-14-2009, 08:32 AM
