Thread: Rear suspension problems
Results 1 to 2 of 2
  1. #1 Rear suspension problems
    Jul 2015
    indianapolis
    i was wondering what would be ghw best way to go about replacing parts in the rear end? My car has dog walked or crab walked since ive had it and at first i thought it was a bent subframe but ive read it could point to other components before it being the subframe. It may be just me but when i looked under there i thought the bar going into the subframe with the adjuster on the end was bent and instead of straight it was rounded( i think its the lateral links?) the rear tires lean to the right angled and that side is the bent lateral link and i was wondering if a bent lateral link woulf make the car dog walk? I know i have to replace tie rods and broken sway bar in the front and i know the alignment is off and didnt know if the combo of the bent link and front end parts needing replaced would cause this to happen. Any advice or input would be greatly appreciated thanks!
  2. #2 Re: Rear suspension problems
    A bent rear trailing arm or lateral arms can make the tire/rim not straight.
    The rear "subframe" is just there for support and have the lateral arms bolt to it.
    I'd get under the car and see exactly what parts are bent and buy what you need.
  1. Please HELP! $1,400 for rear suspension?!?!!?
    By d2produce in forum Brakes/Suspension/Chassis
    Last Post: 04-16-2015, 10:37 AM
  2. Suspension and brake problems, dont know where to start
    By GTLGDP in forum General Tech Discussion
    Last Post: 04-21-2012, 02:27 PM
  3. rear suspension????
    By chancinit666 in forum General Tech Discussion
    Last Post: 06-07-2010, 04:29 PM
  4. rear suspension, 04+
    By sportred04 in forum General Tech Discussion
    Last Post: 03-09-2010, 07:20 PM
  5. Rear suspension help
    By thirdgenfcarnut in forum Brakes/Suspension/Chassis
    Last Post: 08-16-2009, 04:25 PM
