Thread: Lowering spring!
Results 1 to 12 of 12
  1. #1 Lowering spring!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    I'm wanting to install eibach lowering springs I heard you needed to get shorter dog bones and a full alignment after the spring change is this true? Thanks
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: Lowering spring!
    Jul 2010
    Coquitlam,BC,Canada
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Lowering spring!
    no need for short dogbones but you should get an alignment anytime you mess with the struts.
  4. #4 Re: Lowering spring!
    Motor mount spacers are going to be need to correct the axle geometry.
    Shorter dog bones do not correct this problem the right way or if at all.
  5. #5 Re: Lowering spring!
    Oct 2015
    So I was reading the above posted link and it talks about how lowering springs can cause excessive wear on the axles and such which I didn't realize, is that in general or if you just put the springs on without doing anything else for example engine mount spacers?
  6. #6 Re: Lowering spring!
    You are modding the suspension and angles beyond what the factory thought was okay for minimal problems and wear. Once you change that, you are more prone to parts failing and wearing faster.
    Will they really wear faster, maybe or maybe not. Doing the mount spacers is the best support mod to buy for lowering springs/coil-overs, they get it really close or exactly how it was from the factory.
  7. #7 Re: Lowering spring!
    Oct 2015
    OK then that makes a lot if sense I'll have to find out where to get the spacers. Thanks. Also is it OK to put the springs on OEM struts cause I can get springs used for really cheap compared to having to buy a strut/spring combo
  8. #8 Re: Lowering spring!
    ZZP sells spacers I think, though the holes need to be hogged out sometimes to fit really nice. But thats 5 minutes of trial and error with a drill bit, no biggy.
    Stock shocks are fine, they might not last long time if they have alot miles on them already. Add some non pogo washers and you are set.
  9. #9 Re: Lowering spring!
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by suitercrew View Post
    http://chrisb.users.superford.org/Gr.../Lowering.html
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  10. #10 Re: Lowering spring!
    Oct 2015
    What are bearing plates?
  11. #11 Re: Lowering spring!
    Jul 2010
    Coquitlam,BC,Canada
    They connect the strut to the vehicle.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  12. #12 Re: Lowering spring!
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    So, another name for the strut mount is a bearing plate?
    Also, the anti pogo washers are actually the washers for the sub frame. Don't let a store sell you them for $10 a piece when you can just get them from a salvage yard.
    And as far as installing the engine mount spacer, that's what I did when I lowered my 40th Anniversary back in 2008. I also have shortened dog bones. I have the original axles on the car, never had any wear issues and I am at 222K miles
  1. Spring Rates for lowering
    By Nighthwk12 in forum Brakes/Suspension/Chassis
    Last Post: 08-08-2013, 12:28 PM
  2. Lowering spring ride quality?
    By jerZcavy4120 in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2012, 01:34 PM
  3. Possible new Hyperco Lowering spring kit
    By rcdino1978 in forum Group Buys
    Last Post: 06-18-2012, 02:39 PM
  4. Lowering spring question.
    By 1lowcaprice in forum Brakes/Suspension/Chassis
    Last Post: 02-17-2009, 07:22 AM
