Thread: Cheap Addition to 04 Monsoon
Results 1 to 12 of 12
SlowNA06 Cheap Addition to 04 Monsoon 11-17-2010, 05:35 PM
matt5112 Re: Cheap Addition to 04... 11-17-2010, 05:36 PM
rainmkr2 Re: Cheap Addition to 04... 11-17-2010, 06:10 PM
I800C0LLECT Re: Cheap Addition to 04... 11-17-2010, 07:11 PM
SlowNA06 Re: Cheap Addition to 04... 11-18-2010, 12:56 AM
SlowNA06 Re: Cheap Addition to 04... 11-18-2010, 10:41 AM
I800C0LLECT Re: Cheap Addition to 04... 11-19-2010, 12:01 AM
matt5112 Re: Cheap Addition to 04... 11-19-2010, 12:05 AM
I800C0LLECT Re: Cheap Addition to 04... 11-19-2010, 01:05 AM
SlowNA06 Re: Cheap Addition to 04... 11-19-2010, 01:13 AM
I800C0LLECT Re: Cheap Addition to 04... 11-19-2010, 08:36 AM
SlowNA06 Re: Cheap Addition to 04... 11-19-2010, 10:14 AM
  1. #1 Cheap Addition to 04 Monsoon
    Pennsylvania
    Buddy of mine wants to sell his current used audio setup. $400, and he'll do the install for free. I just want to get an opinion on the gear (and/or price), if you might be so kind as to lend me a moment of your time to review them.
    The car it will go in is an '04 GP with the Monsoon system.
    Memphis Class D MClass 16-MC1.1100
    Pioneer TS-W3001D2|D4 12" Sub with 1 cubic ft custom box
    Stinger SPC021 Capacitor - I've done some reading, which seems to indicate that this is pointless? I can save $50 if I don't buy this (so $350 total for amp and sub in box)
    EDIT: Nevermind on those Pioneer speakers - I'll just find something cheap and easy online.
    The goal here is cheap and clean. Thoughts, opinions? THANKS!
  2. #2 Re: Cheap Addition to 04 Monsoon
    Didn't catch that your rears were currently blown out.
    I'd either remove them and leave them out or throw the pio's in there.
  3. #3 Re: Cheap Addition to 04 Monsoon
    SE Level Member rainmkr2's Avatar
    UpState, NY
    The current Pioneer Sub like that one (TS-W3002D2) goes for $150 plus shipping.
    SonicElectronix.com I've got a baby Pioneer 10" in my TA with a 400watt Alpine Mono-D and it works great, no complaints.
    The Memphis amp seems to be going for around $480 on line. Don't know anything about them but the specs look good.
    I assume the Pioneer is a dual 2ohm, so you would be running in parallel for a 1 ohm load at the amp. That amp is rated at 1000watts @ 1ohm. Should wake up the neighbors pretty well. The cap might help keep your lights from dimming on bass hits a bit.
    The weak link is going to be the head unit.
    Check this out: http://www.grandprixforums.net/06-mo...rap-36872.html
    You are going to have trouble with the 6x9's because the Monsoon rear speakers are bi-amped. If you are crafty you can probably rig it up by cutting the tweeter leads and wiring them separately. Just make sure the cap is still in the circut. I'd also suggest putting caps on the 6x9 woofers to keep them from bottoming out.
    If you can listen to it before you buy it, and your buddy knows what he is doing looks like an OK deal.
    My $0.02.
    Pontiac - RIP 2009!!
    1998 - GTP - Winter
    2006 - GXP - Sping/Fall
    1991 - TA DropTop - Summer
  4. #4 Re: Cheap Addition to 04 Monsoon
    Feb 2009
    Virginia
    Well considering the rest of your speakers won't be able to keep up with the sub because you'll probably max out the settings on your amp...do you give a damn about the quality of your speakers? It's really a subjective question. There seems to be a lot of people ok with running everything through a string and coke cans so long as the subs give people headaches.
    If you want a good install...it's going to take more than just a sub. Good clean bass requires decent mids. There's a lot of reasons for that but I won't get into a lesson here. If you want the most out of your sub that requires matching it with the mids in your current install. Mid range contour effects the bass line A LOT!!!
    So instead of doing all the research or asking us to why not find a way to "test" the setup in your vehicle before doing a permanent install?
    11 is louder than 10!
  5. #5 Re: Cheap Addition to 04 Monsoon
    Pennsylvania
    Eh, it looks like those speakers in my basement are 5x7's. So, whatever, I'll just pick up some cheap speakers to fill it out the 6x9 slots... something in the $100/pair range.
    I listened to the system tonight in his truck. It's actually pretty nice. The sub had a leak and needed to be screwed back in to the box, which he'll take care of (never noticed until I pointed it out and pinched it to seal, now his OCD is kicking in to fix it). For the record, it handled Crunk Juice quite nicely, though he usually listens to metalcore and such.
    He said it was currently set up at 2 Ohms because he had a problem with the sub drawing too much power at 1 Ohm or something. But if I buy it, he'll take care of helping me tune the equipment for my needs.
    As far as overall sound quality is concerned, I will eventually upgrade to nicer things, but for now I'm interested in limping along and happened to come across a decent deal. As a snobby musician with a half-decent ear, I always make sure I'm not just producing loud noises.
  6. #6 Re: Cheap Addition to 04 Monsoon
    Pennsylvania
    Hah, sweet, Morad's selling me a full set of the Monsoon speakers on the cheap. That ought to help me limp along until I figure out something to really keep up with the sub.
    He tells me he's going to pick up high pass filters to do manually what a nice head unit would (I have yet to do any kind of reading on this, so I'm just taking his word for it).
    Thanks for the help everyone!
  7. #7 Re: Cheap Addition to 04 Monsoon
    Feb 2009
    Virginia
    His truck won't sound the same as your grand prix...it'll be entirely different
  8. #8 Re: Cheap Addition to 04 Monsoon
  9. #9 Re: Cheap Addition to 04 Monsoon
    Feb 2009
    Virginia
    ha
  10. #10 Re: Cheap Addition to 04 Monsoon
    Pennsylvania
    Lol, yeah, I realize there's a difference in our speaker setups, air, distance, etc. I just wanted to hear the sub in operation, make sure everything was kosher.
  11. #11 Re: Cheap Addition to 04 Monsoon
    Feb 2009
    Virginia
    Gotcha...I wasn't sure if that was in my response to the suggestion of finding a way to quickly set it up in your vehicle. I think it's a decent deal and if you don't mind planning a system based on that amp in the future, or have no qualms with mismatching amps...take it and run. Subs are easy to sell/trade/whatever.
  12. #12 Re: Cheap Addition to 04 Monsoon
    Pennsylvania
    Yeah, I'm just playing this audio thing by ear (oops, unintentional, promise), but rest assured that I will inve-..er... waste money on getting it just right later.
  1. monsoon add on?
    By Morris 04 GTP in forum Audio, Security & Visual Electronics
    Last Post: 11-18-2010, 12:04 PM
  2. Newest Addition to the GP family
    By Biohazed in forum General Tech Discussion
    Last Post: 10-26-2010, 09:50 PM
  3. Addition to the GP Family..
    By Jenbolee in forum Introductions/Noob Questions
    Last Post: 08-11-2009, 01:46 PM
  4. another addition to my airbrushing
    By whitcomb in forum Visual/Body Modifications
    Last Post: 01-27-2008, 01:21 AM
