Thread: HUD not working and Odometer numbers stuck together, fix?
Results 1 to 2 of 2
  1. #1 HUD not working and Odometer numbers stuck together, fix?
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    So, on my way back from buying my '99 GTP I tried out the HUD, but all it did was make this scratchy/clickty noise, probably just a bad fuse - or is there something else common that goes wrong with HUDs?
    Also, I bought the car with 133k on it, it turned over to 134k on the way but the two 3s stuck together and now it reads 144k - there's also a white line between the two fours which was barely there before, I heard this is some sort of tamper-signal. Is there any way to fix this? I also have another gauge cluster (with 225k), is it possible to swap that in for 10k miles then put the original back in? I don't really like the possibility of it turning over 10k for every 1k miles...
  2. #2 Re: HUD not working and Odometer numbers stuck together, fix?
    Jun 2015
    Lake Isabella, CA
    Clusters are easily interchanged. I did one on a 2000 Regal I once owned.
  1. key stuck and shifter button stuck 50% of the time
    By brugg125er in forum General Tech Discussion
    Last Post: 03-21-2014, 10:21 AM
  2. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  3. odometer stopped working help?
    By itsvo09 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 04:07 PM
  4. speedoand odometer stopped working
    By 1999gpgt in forum General Tech Discussion
    Last Post: 09-27-2009, 09:45 PM
