Thread: Sound deadening and you...
Results 1 to 11 of 11
  1. #1 Sound deadening and you...
    GXP Level Member
    Mar 2015
    Tomball
    So I've had a couple of people ask me about sound deadening and what they should do. Here's the basics (and I mean basic) of how it works and what you want to do for maximum noise reduction.
    Basically sound deadening boils down to 3 types. Dampening, insulating and cancellation. The 3rd option is kind of out since it requires electronics, amplifiers and speakers to cancel unwanted sound. Basically it's the same noise played 180* out of phase. This is how noise canceling headphones work. The tech has been around for a while and when I was in tech school I actually built a system to do this. It worked great, it was one of my projects for the course and then a few years later companies like Mercedes, and others used this technology to quiet their vehicles.
    Dampening is one of the more useful and typically you will place a material like Dynamat on large sections of panels to lower their resonant frequency below the level that causes it to easily transfer noise into the interior. Panels like the floor pans and areas like around the strut tower are areas where it helps. Doors are another area that need attention, both inner and outer panel. A lot of people will not take the time to put any material on the outer skin of the door. It's hard to get to, but the results become much better. One myth about doing this is that you cover the entire panel, you don't you cover large sections. For instance let's say the outer door skin is 36"X36" to dampen a door skin that size it's not necessary to add a 36" square piece to it add a piece roughly 18" square in the middle of the door. If there is a bar in the way then cut it in half and put one above and one below.
    For the inner door usually just around the speaker is the area you are going to focus on. Then add smaller pieces to large areas on the panel, as I said before don't cover the whole thing, you are just trying to add some weight to the panel so that energy is not transferred into and through the panel easily. Now for the floorpans it's the same thing you want to add mass to the areas that are large and unsupported as they act as a sounding board and transmit sound through the panel. Again it's not necessary to cover the whole panel. The transmission tunnel is an area to add mass as well usually about 2/3's coverage. Same with under the seats and in the trunk and around the spare tire well. Usually you will already see some material in these areas in the back as well, just clean and match the size of the material over it. The trunk lid is another area to add some mass all the little cutout areas between the bracing can have pieces installed there as well. Installation is critical for it to last. Products like Dynamat are pretty stiff when cold and that's where a heat gun comes in handy,conversely you can lay the sheets in the sun and allow the sun to make the material pliable, not so easy in winter unless you have a room temperature area with a glass window like a patio door. Cleanliness is a high priority as well you need to clean the areas you are going to attach it to as well. Heating the panel helps as well and having a few tools on hand like a heat gun, a wooden roller about an inch or so wide with a handle to press the material down and some pieces of dowel rod with rounded ends to press it into corners. Use your imagination when it comes to tools.
    Insulation. As you know adding insulation will help keep out noise by making it harder to get through because it is absorbed by the material. Just about any high density closed cell foam will help this. In this case you want to cover the whole panel this is where when you have gaps you have areas that are going to allow sound into the cabin. Personally when I install something like this I will use contact cement and touch up gun to spray the panel and the material wait 20 minutes and put it into place. It's hard to reposition at this point so having help to get the panel down helps. This isn't a quick afternoon kind of job this is usually accomplished in a day or two.
    Another point I want to touch on is panel vibrations. As cars age the adhesives used to secure one panel to the other become brittle and break loose and allow the two panels to contact one and other. The trunk is a perfect example the bracing to outer skin will typically separate and the two panels will cause added noise. What I have always done for this is to use expanding foam and just go between the bracing and panel through the holes you have access too and spray a small amount in there in several spots this will keep the panels from making racket. You must be extremely careful though as if you add too much you will end up with the foam pushing out on the outer skin and you're pretty much screwed then. I had a guy watching as I applied this method to the trunk of a car and he decided he would just go whole Hogg and fill up the whole thing with expanding foam. Next day he comes back to our shop and has a big raised W on the trunk lid and when I asked him what he did he opened the trunk and the braces were full with about a 1/2" gap between the bracing and trunk panel. Don't be fooled by expanding foam it has a lot of power and can literally tear panels apart.
    That's about all I can think of for now.
    Jeff
  2. #2 Re: Sound deadening and you...
    Jun 2015
    Clearwater, FL
    I'd also like to add, if there's an area that is too tricky to get to by hand with the traditional sound deadener that comes in sheets and is cut-to-fit, DEI makes a spray on sound deadening product called Boom Mat. In previous installs, I've used the dynomat in the doors and then sprayed a layer of boom mat over it. Very good combination, and other companies offer similar spray on products at the FLAPS.
    P.S. this should be a sticky!
  3. #3 Re: Sound deadening and you...
    GXP Level Member
    Mar 2015
    Tomball
    Good call on the spray it's been a while since I have used it, as I recall it was a lot like undercoating and like you said it wirks when you can't get into an area. Stinger made some as well, though I don't know if they are even in business anymore.
    Jeff
  4. #4 Re: Sound deadening and you...
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    I think its important to talk about mass loaded vinyl too which is used to block and absorb sound waves.
    Dynomat on the middle of panels that resonate to deaden them. Limp mass vinyl (can order at Home Depot, Amazon, Ebay, etc) sheets on doors, floor, etc. to block and absorb sound waves. And closed cell foam or jute insulation in cavities to absorb sound waves. LMV and insulation absorb the sound waves and convert them to heat.
  5. #5 Re: Sound deadening and you...
    GXP Level Member
    Mar 2015
    Tomball
    Those are good points as well, LMV is another good material as well. My whole point is that sound deadening is not a one step approach. It is best to have an understanding on how sound gets into a car. I always wanted sound deadening window tint, as windows are an area where you can't do much at all.
    Jeff
  6. #6 Re: Sound deadening and you...
    Enfield, CT
    pics? lol
  7. #7 Re: Sound deadening and you...
    GXP Level Member
    Mar 2015
    Tomball
    Lol, I can show you some pics of some old rolls and such but they've been around since before digital cameras. matter of fact most everything I did was before digital cameras. All we had were Polaroids... and we were damn glad to have them!
    When I install some sound deadening in my car I will take pics. Unfortunatly I don't have access to the RTA SA3055 anymore, all I have is a cheap Db meter and a phone that doesn't have the dynamic range needed to produce reliable results, but I may find a way...
    Jeff
  8. #8 Re: Sound deadening and you...
    Jul 2014
    Toledo, OH
    I don't have any pics but I removed the door panels and plastic sheeting. Put a square of dynomat on the inside of the outer door skin. Put dynomat over the openings of the inner sheet skin. Hung mlv from the top. Stuck jute pad in openings of plastic door panel.
    Sent from my HTC One using Tapatalk
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  9. #9 Re: Sound deadening and you...
    Buffalo
    Where's the roof patch guy?
  10. #10 Re: Sound deadening and you...
    Jan 2014
    AR
    Quote Originally Posted by CrazyGuy03 View Post
    Is it raining?
    My best sound deadening jobs fall into a time window where most of my pics were lost to a HDD failure. Looks like silver stuff stuck all over the place.
    Products that recent customers have been very satisfied with:
    http://www.thermotec.com/products/all.html
    http://www.lizardskin.com/
    IMO, lots of folks tend to overkill sound deadening and use an overly expensive shotgun approach, covering every inch of everything. I believe strategic placement can yield similar results using much less product. Found a few pics of when I was doing the dash area of a 67 Chevy.
  11. #11 Re: Sound deadening and you...
    GXP Level Member
    Mar 2015
    Tomball
    My point exactly.
    Jeff
  1. Grinding sound when making sharp left and awful creak sound when going over bumps
    By rescuetoaster in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2012, 10:06 PM
  2. Sound Deadening
    By dpzelenak in forum Audio, Security & Visual Electronics
    Last Post: 11-27-2011, 01:01 PM
  3. how to get more sound out of s/c?
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2010, 01:31 PM
  4. S/C Sound
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 11-18-2008, 10:33 PM
  5. what should i do to get this sound?
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2008, 07:22 PM
