Thread: Tail Light Socket is bad - trying to disassemble and fix
Results 1 to 4 of 4
  1. #1 Tail Light Socket is bad - trying to disassemble and fix
    Oct 2012
    Illinois
    I've had tail light issues (as many others have) for a few months. The stock tail lights were filling up with water.. so I ordered aftermarket replacements and installed them this week. I assumed the water was shorting the bulbs out, but now I'm finding out that the socket that the center lamp that stays on, and also is the brake light, is not connecting properly. When I plug the new led plug into that socket, it will sporadically connect but never stay on. I tried using a small screwdriver to adjust the contacts in the socket so that they made more contact, but it doesn't seem to be working. My last resort is to go the the salvage yard and find a new socket, but I wondered if anyone has ever had success in taking it apart. It has 2 tabs on either side that you can depress and possibly remove the inner part, but no matter how I try it doesn't want to budge.
  2. #2 Re: Tail Light Socket is bad - trying to disassemble and fix
    you can buy new sockets. cut and solder them on.
    id try some sand paper in the sockets first, then some bulb grease if it still dont work replace the sockets.
    led's have their own issues, so make sure its not them, try the normal bulbs again too.
  3. #3 Re: Tail Light Socket is bad - trying to disassemble and fix
    come think of it, the sockets may unplug from the harness. my fronts did. very small plug at the end. not sure about the rears, aint seen mine in years now.
  4. #4 Re: Tail Light Socket is bad - trying to disassemble and fix
    Oct 2012
    Illinois
    Ended up being the socket. Got a new one wired on and it fixed the problem. Just took a trip to the junk yard to find it!
  1. tail light and dash light issue
    By cshank98pace car in forum General Grand Prix Discussion
    Last Post: 09-08-2013, 11:20 AM
  2. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  3. 98 GTP Tail light Mod?
    By darkfox1009 in forum Visual/Body Modifications
    Last Post: 08-02-2011, 05:21 AM
  4. Disassemble/Reassemble GP seats?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 08-04-2008, 06:54 AM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
