Thread: AUX/Bluetooth input
Results 1 to 10 of 10
  1. #1 Re: AUX/Bluetooth input
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    The "BlueStar" onstar replacement is like $300 if I recall correctly.
    If you have a tape deck in your radio, they make an adapter for that, but they are common knowledge so I'm guessing your unit doesn't have a tape deck.
    I believe they have FM transmitters fairly cheap, which you plug your MP3 player /etc. into and tune your radio to the transmitter's frequency. I've heard the audio quality is hit or miss this way, but it's a simple solution.
    Lastly, you could potentially open up your radio and install an aux jack in there. I've done this with a couple of radios. Basically, you find where the left and right audio come from the CD player (don't forget ground!) and tap into them for your jack. Then you put a blank CD into the CD player, and the car will think it's playing a CD, but instead play whatever you plug into the jack. Radio Shack has the jack port that you can install, only costs a few dollars plus some solder and wiring.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: AUX/Bluetooth input
    Jul 2013
    Lockeport Nova Scotia Canada
    will using the audio inputs from the auxuliary rear trunk cd changer also work to put an adaptor on to plug in a jack?
  1. Bluetooth
    By Neiun in forum 5.3L V8 (LS4)
    Last Post: 07-15-2013, 05:58 PM
  2. Aux off of XM (Bluetooth help)
    By kjhud in forum Audio, Security & Visual Electronics
    Last Post: 04-26-2013, 11:24 AM
  3. Bluetooth tuning?
    By Wakeboy1337 in forum PCM Tuning
    Last Post: 03-21-2011, 07:40 PM
  4. need some input input input.(short circuit)
    By IR II IP IDEATH in forum 5.3L V8 (LS4)
    Last Post: 02-17-2010, 03:23 AM
