Thread: Possible problem
Results 1 to 2 of 2
  1. #1 Possible problem
    May 2015
    Minnesota
    I was putting a new head unit in my 04 Grand Prix and I made a stupid mistake. I wasn't paying full attention to the wires when I was pushing the head unit in, ended up pinching the power wire and frying the interface. It appeared that nothing else was damaged, it all looked okay, so I put the factory stereo back in until I could get a new interface. Now when I try to start the car it says "starting disabled due to theft system". Did I mess up something major?
  2. #2 Re: Possible problem
    St. Louis
    Not really, but from what I found on Google the relearn proceedure may have to be done. Here is what I found:
    ok, you need to do the 30 minute relearn procedure:
    1. Turn ON the ignition, with the engine OFF.
    2. Attempt to start the engine, then release the key to ON (vehicle will not start).
    3. Observe the SECURITY telltale(security light), after approximately 10 minutes the telltale will turn OFF.
    4. Turn OFF the ignition, and wait 5 seconds .
    5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes (the vehicle is now ready to relearn the Passlock(TM) Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK). IMPORTANT: The vehicle learns the Passlock(TM) Sensor Data Code and/or password XXXXX the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
    6. Start the engine (the vehicle has now learned the Passlock(TM) Sensor Data Code and/or password).
    7. With a scan tool, clear any DTCs if needed (history DTCs will self clear after 100 ignition cycles).
    Read more: http://www.justanswer.com/pontiac/6i...#ixzz3apnBMFG2
  1. of course. another problem
    By m17davis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2014, 12:06 PM
  2. Need a direction to my GP's problem - FWD problem
    By isaac33 in forum General Grand Prix Discussion
    Last Post: 02-26-2013, 11:36 AM
  3. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  4. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  5. this might be a problem soon
    By Yung615 in forum Introductions/Noob Questions
    Last Post: 10-25-2009, 09:50 AM
