naw man i got 4 saz-3000d's and 2 nightshade 15's in my f150 and 2 3000's and 2 nightshade 12's in my gt. very true about the product selection. jl is nice but way overrated. i always tell people to buy jl's TMA line. it is the same quality and company just a hell of alot cheaper
well got the tweeters installed in the door panels today. i was gonna run them in the a-pillars but the vc100's mounting tactics would have made that a little hard for me.
i think this will do fine though. here are some pics
blackbonnie - I have a 2005 that needs a new passenger side window switch. I have the $13 switch but haven't a clue how to get at the old switch other than rip the interior door panel off... Do you still have your front passenger side door panel off as seen in one of the pictures above (I'm wondering how to get the window switch out)? If so, would you please check this out for me, snap a picture, and post it or you could e-mail it to me if you wanted and I would then give you my e-mail address?
Thanks from a Newbie!
On edit: If I need to remove the door panel, is there a trick or special tool required or are there simply metal clips and/or "Xmas tree" plugs holding it in place?
no trick to getting the panel off, just take out 2 bolts (located in your handle, the white part in the lat pic above. i believe they are 10mm)
then after that, just pry the panel off working your way around. lift the door panel up and pull. unplug the wires and your there. real simple to get off once you get the bolts out. dont worry, you wont break anything.
there should be more updates soon......
Good. I was wondering how the build was coming.
looks real good cant wait to see it when its all done.
looking good there
should have my new rca's ran this weekend, final run of 1/0, and possibly my front stage finished if i ever get my shipment in....
progress?
